CCPM: A Scalable and Noise-Resistant Closed Contiguous Sequential Patterns Mining Algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Mining closed contiguous sequential patterns has been addressed in the literature only recently, through the CCSpan algorithm. CCSpan mines a set of patterns that contains the same information than traditional sets of closed sequential patterns, while being more compact due to the contiguity. Although CCSpan outperforms closed sequential pattern mining algorithms in the general case, it does not scale well on large datasets with long sequences. Moreover, in the context of noisy datasets, the contiguity constraint prevents from mining a relevant result set. Inspired by BIDE, that has proven to be one of the most efficient closed sequential pattern mining algorithm, we propose CCPM that mines closed contiguous sequential patterns, while being scalable. Furthermore , CCPM introduces usable wildcards that address the problem of mining noisy data. Experiments show that CCPM greatly outperforms CCSpan, especially on large datasets with long sequences. In addition, they show that the wildcards allows to efficiently tackle the problem of noisy data.
CCPM A Scalable and Noise-Resistant Closed Contiguous Sequential Pattern....pdf (331.09 Ko) Télécharger le fichier
hal-01569008 , version 1 (26-07-2017)
Yacine Abboud, Anne Boyer, Armelle Brun. CCPM: A Scalable and Noise-Resistant Closed Contiguous Sequential Patterns Mining Algorithm. 13th International Conference on Machine Learning and Data Mining MLDM 2017, Jul 2017, New York, United States. pp.15, ⟨10.1016/j.knosys.2015.06.014⟩. ⟨hal-01569008⟩
244 Consultations
481 Téléchargements
