Decision-Support System for Urban Air Pollution under Future Climate Conditions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Steen Solvang Jensen
  • Fonction : Auteur
  • PersonId : 1013673
Jørgen Brandt
  • Fonction : Auteur
  • PersonId : 1013674
Martin Hvidberg
  • Fonction : Auteur
  • PersonId : 1013675
Matthias Ketzel
  • Fonction : Auteur
  • PersonId : 1013676
Jens Hesselbjerg Christensen
  • Fonction : Auteur
  • PersonId : 1013677
Climate change is expected to influence urban living conditions and challenge the ability of cities to adapt to and mitigate climate change. Urban climates will be faced with elevated temperatures and future climate conditions are expected to cause higher ozone concentrations, increased biogenic emissions from vegetation, changes in the chemistry of the atmosphere and changes in deposition of particulate air pollution. This paper describes a conceptual outline of a decision-support system for assessment of the impacts of climate change on urban climate and air quality, and for assessment of integrated climate change and air pollution adaptation and mitigation strategies.
978-3-642-22285-6_69_Chapter.pdf (121.33 Ko) Télécharger le fichier
hal-01569191 , version 1 (26-07-2017)
Paternité
Steen Solvang Jensen, Jørgen Brandt, Martin Hvidberg, Matthias Ketzel, Gitte Brandt Hedegaard, et al.. Decision-Support System for Urban Air Pollution under Future Climate Conditions. 9th International Symposium on Environmental Software Systems (ISESS), Jun 2011, Brno, Czech Republic. pp.641-650, ⟨10.1007/978-3-642-22285-6_69⟩. ⟨hal-01569191⟩
40 Consultations
78 Téléchargements
