Modelling Dynamics in Collaboration: An Extension to the Collaborative Network Relationship Analysis
This is a concept paper which introduces a dynamic extension to a collaborative network relationship analysis approach. The extension is based on the MetaMatrix approach known from the Dynamic Network Analysis field. Several entity classes representing agents, tasks, resources and knowledge are introduced and possible relations between entities of the different classes are analysed. All entity classes and relation classes are attributed with time related data which allows dynamic changes the system. Finally, some illustrative examples of typical collaborative interactions are introduced and explained.
