A Structured Methodology to Implement Performance Measurement Systems in Collaborative Networks
Collaboration is one of the most commonly used strategies in the business environment. Enterprises that collaborate need reliable and efficient performance information. However, many collaborative enterprises fail to implement a common performance measurement system in an adequate manner due to the lack of sound mechanisms that connect all the elements within a performance measurement system. The purpose of this paper is to provide a methodology based on a multi-criteria decision method that aids to implement the different elements that compose a performance measurement system for collaborative networks. With this methodology enterprises have a tool to define all the aspects involved in the performance measurement system and to implement it. This approach has been applied to a collaborative enterprise network belonging to the automotive sector.
