A level set based method for fixing overhangs in 3d printing, Applied Mathematical Modelling, vol.44, pp.446-455, 2017. ,
3D texture mapping for rapid manufacturing, Comput. Aided Des. Appl, vol.4, issue.6, pp.761-771, 2007. ,
Space-filling curves in tool-path applications, Computer-Aided Design, vol.26, issue.3, pp.215-224, 1994. ,
Modeling and toolpath generation for consumer-level 3D printing, ACM SIGGRAPH 2015 Courses, vol.17, p.273, 2015. ,
Bridging the gap: automated steady scaffoldings for 3D printing, ACM Transactions on Graphics, vol.33, issue.4, pp.1-98, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01100737
Method and apparatus for automatic support generation for an object made by means of a rapid prototype production method, 2007. ,
Toolpath based on Hilbert's curve, Computer-Aided Design, vol.26, issue.11, pp.839-844, 1994. ,
Method for generating and building support structures with deposition-based digital manufacturing systems, US Patent, 2010. ,
Real-time shaded NC milling display, Proceedings of SIGGRAPH, pp.15-20, 1986. ,
Iterative carving for self-supporting 3D printed cavities, Eurographics 2018-Short Papers, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01764291
Tight printable enclosures for additive manufacturing, Technical Report, vol.8712, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01399931
Tight printable enclosures and support structures for additive manufacturing, EG Workshop on Graphics for Digital Fabrication, 2016. ,
Algorithms for layered manufacturing in image space, ASME Advances in Computers and Information in Engineering Research, vol.1, pp.377-410, 2014. ,
Sloping wall structure support generation for fused deposition modeling, Int. J. Adv. Manuf. Tech, vol.42, pp.1074-1081, 2009. ,
A C++ geometric library for boolean operations on polygons ,
2D Segment Delaunay Graphs, CGAL User and Reference Manual, 2016. ,
Block-based inner support structure generation algorithm for 3D printing using fused deposition modeling, International Journal of Advanced Manufacturing Technology, 2016. ,
3D infilling: faster, stronger, simpler, 2015. ,
Interior structural optimization based on the density-variable shape modeling of 3D printed objects, Int. J. Adv. Manuf. Tech, vol.83, issue.9, pp.1627-1635, 2015. ,
Extended grassfire transform on medial axes of 2D shapes, Computer-Aided Design, vol.43, issue.11, 2011. ,
From 3D Models to 3D Prints: An Overview of the Processing Pipeline, Computer Graphics Forum, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01518469
Build-to-last: Strength to weight 3D printed objects, ACM Trans. Graph, vol.33, issue.4, p.97, 2014. ,
Advanced numerical methods to optimize cutting operations of five axis milling machines, 2007. ,
Procedural Voronoi foams for additive manufacturing, ACM Trans. Graph, vol.35, issue.4, 2016. ,
Chained segment offsetting for ray-based solid representations, Computers & Graphics, vol.46, pp.36-47, 2015. ,
Layered manufacturing of thin-walled parts, ASME Design Engineering Technical Conference, 2000. ,
Adaptive voids, Vis. Computer, pp.799-808, 2015. ,
Elastic textures for additive fabrication, ACM Trans. Graph, vol.34, issue.4, 2015. ,
Procedural function-based modelling of volumetric microstructures, Graphical Models, vol.73, issue.5, pp.165-181, 2011. ,
Computer-aided design for additive manufacturing of cellular structures, Comp. Aided Des. Appl, vol.4, issue.5, 2007. ,
Branching support structures for 3D printing, ACM SIGGRAPH 2014 Studio, p.9, 2014. ,
Microstructures to control elasticity in 3D printing, ACM Trans. Graph, vol.34, issue.4, pp.1-136, 2015. ,
Clever support: efficient support structure generation for digital fabrication, Computer Graphics Forum, vol.33, issue.5, pp.117-125, 2014. ,
GPU-based offset surface computation using point samples, Computer-Aided Design, vol.45, issue.2, pp.321-330, 2013. ,
Cost-effective printing of 3D objects with skin-frame structures, ACM Trans. Graph, vol.32, issue.6, p.177, 2013. ,
Self-supporting rhombic infill structures for additive manufacturing, Computer-Aided Design, vol.80, 2016. ,
Medial axis tree-an internal supporting structure for 3D printing, Comput. Aided Geom. D, pp.149-162, 2015. ,
Connected Fermat spirals for layered fabrication, ACM Trans. Graph, vol.35, issue.4, pp.1-10, 2016. ,
