Remanufacturing System: Characterizing the Reverse Supply Chain - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
End-of-life strategies, such as remanufacturing, have gained ground in order to promote product reuse, reduce environmental impacts and costs, as well as to win new markets. The remanufacturing process preserves part of the product’s raw materials and added value during its manufacturing. This study addresses the system that includes remanufacturing in order to understand it and to define its elements, as well as to characterize the supply chain that permeates and leads to the effective functioning of this system. To this end, a Systematic Literature Review on remanufacturing was conducted. Moreover, the RS proposed was based on the General Systems Theory.
978-3-642-23330-2_60_Chapter.pdf (460.08 Ko) Télécharger le fichier
hal-01570557 , version 1 (31-07-2017)
Paternité
Ana Barquet, Henrique Rozenfeld, Fernando A. Forcellini. Remanufacturing System: Characterizing the Reverse Supply Chain. 12th Working Conference on Virtual Enterprises (PROVE), Oct 2011, São Paulo, Brazil. pp.556-563, ⟨10.1007/978-3-642-23330-2_60⟩. ⟨hal-01570557⟩
86 Consultations
66 Téléchargements
