Composite biomarkers derived from Micro-Electrode Array measurements and computer simulations improve the classification of drug-induced channel block - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Frontiers in Physiology Année : 2018
The Micro-Electrode Array (MEA) device enables high-throughput electrophysiology measurements that are less labour-intensive than patch-clamp based techniques. Combined with human-induced pluripotent stem cells cardiomyocytes (hiPSC-CM), it represents a new and promising paradigm for automated and accurate in vitro drug safety evaluation. In this article, the following question is addressed: which features of the MEA signals should be measured to better classify the effects of drugs? A framework for the classification of drugs using MEA measurements is proposed. The classification is based on the ion channels blockades induced by the drugs. It relies on an in silico electrophysiology model of the MEA, a feature selection algorithm and automatic classification tools. An in silico model of the MEA is developed and is used to generate synthetic measurements. An algorithm that extracts MEA measurements features designed to perform well in a classification context is described. These features are called composite biomarkers. A state-of-the-art machine learning program is used to carry out the classification of drugs using experimental MEA measurements. The experiments are carried out using five different drugs: mexiletine, flecainide, diltiazem, moxifloxacin and dofetilide. We show that the composite biomarkers outperform the classical ones in different classification scenarios. We show that using both synthetic and experimental MEA measurements improves the robustness of the composite biomarkers and that the classification scores are increased.
paper_hal.pdf (2.21 Mo) Télécharger le fichier
supplementary_material.pdf (195.5 Ko) Télécharger le fichier
hal-01570819 , version 1 (31-07-2017)
hal-01570819 , version 2 (30-10-2017)
hal-01570819 , version 3 (13-12-2017)
Eliott Tixier, Fabien Raphel, Damiano Lombardi, Jean-Frédéric Gerbeau. Composite biomarkers derived from Micro-Electrode Array measurements and computer simulations improve the classification of drug-induced channel block. Frontiers in Physiology, 2018, 8 (1096), pp.1-30. ⟨10.3389/fphys.2017.01096⟩. ⟨hal-01570819v3⟩
715 Consultations
292 Téléchargements
