NNIGnets, Neural Networks Software
NNIGnets is a freeware computer program which can be used for teaching, research or business applications, of Artificial Neural Networks (ANNs). This software includes presently several tools for the application and analysis of Multilayer Perceptrons (MLPs) and Radial Basis Functions (RBFs), such as stratified Cross-Validation, Learning Curves, Adjusted Rand Index, novel cost functions, and Vapnik–Chervonenkis (VC) dimension estimation, which are not usually found in other ANN software packages. NNIGnets was built following a software engineering approach which decouples operative from GUI functions, allowing an easy growth of the package. NNIGnets was tested by a variety of users, with different backgrounds and skills, who found it to be intuitive, complete and easy to use.
Informatique [cs]
