NNIGnets, Neural Networks Software - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Tânia Fontes
  • Fonction : Auteur
  • PersonId : 1014087
Vânia Lopes
  • Fonction : Auteur
  • PersonId : 1014088
Luís M. Silva
  • Fonction : Auteur
  • PersonId : 1014089
Joaquim Marques de Sá
  • Fonction : Auteur
  • PersonId : 1014091
NNIGnets is a freeware computer program which can be used for teaching, research or business applications, of Artificial Neural Networks (ANNs). This software includes presently several tools for the application and analysis of Multilayer Perceptrons (MLPs) and Radial Basis Functions (RBFs), such as stratified Cross-Validation, Learning Curves, Adjusted Rand Index, novel cost functions, and Vapnik–Chervonenkis (VC) dimension estimation, which are not usually found in other ANN software packages. NNIGnets was built following a software engineering approach which decouples operative from GUI functions, allowing an easy growth of the package. NNIGnets was tested by a variety of users, with different backgrounds and skills, who found it to be intuitive, complete and easy to use.
978-3-642-23957-1_39_Chapter.pdf (148.05 Ko) Télécharger le fichier
hal-01571351 , version 1 (02-08-2017)
Paternité
Tânia Fontes, Vânia Lopes, Luís M. Silva, Jorge M. Santos, Joaquim Marques de Sá. NNIGnets, Neural Networks Software. 12th Engineering Applications of Neural Networks (EANN 2011) and 7th Artificial Intelligence Applications and Innovations (AIAI), Sep 2011, Corfu, Greece. pp.345-350, ⟨10.1007/978-3-642-23957-1_39⟩. ⟨hal-01571351⟩
43 Consultations
71 Téléchargements
