Conference papers
Maximum Shear Modulus Prediction by Marchetti Dilatometer Test Using Neural Networks
Abstract : The use of Neural Networks for modeling systems has been widespread, in particular within areas where the great amount of available data and the complexity of the systems keeps the problem very unfriendly to treat following traditional data analysis methodologies. In the last two decades, small strain shear modulus became one of the most important geotechnical parameters to characterize soil stiffness. Finite element analysis have shown that in-situ stiffness of soils and rocks is much higher than was previously thought, and that stress-strain behaviour of these materials is non-linear in most cases with small strain levels, especially in the ground around retaining walls, foundations and tunnels typically in the order of 10− 2 to 10− 4 of strain. Although the best approach seems to be based in measuring seismic wave velocities, deriving the parameter through correlations with in-situ tests is usually considered very useful for design practice. In this work, a new approach using Neural Networks is proposed for sedimentary soils and the results are discussed and compared with some of the most common available methodologies for this evaluation.
Document type :
Conference papers
Complete list of metadata
Cited literature [18 references]  Display  Hide  Download
https://hal.inria.fr/hal-01571370
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Wednesday, August 2, 2017 - 11:41:57 AM
Last modification on : Friday, April 22, 2022 - 11:42:05 AM
File
978-3-642-23957-1_38_Chapter.p...
Identifiers
Citation
Manuel Cruz, Jorge M. Santos, Nuno Cruz. Maximum Shear Modulus Prediction by Marchetti Dilatometer Test Using Neural Networks. 12th Engineering Applications of Neural Networks (EANN 2011) and 7th Artificial Intelligence Applications and Innovations (AIAI), Sep 2011, Corfu, Greece. pp.335-344, ⟨10.1007/978-3-642-23957-1_38⟩. ⟨hal-01571370⟩
Share
Metrics
Record views
30
Files downloads
109
