New interface
Conference papers
A New Criterion for Clusters Validation
Abstract : In this paper a new criterion for clusters validation is proposed. This new cluster validation criterion is used to approximate the goodness of a cluster. The clusters which satisfy a threshold of this measure are selected to participate in clustering ensemble. For combining the chosen clusters, a co-association based consensus function is applied. Since the Evidence Accumulation Clustering method cannot derive the co-association matrix from a subset of clusters, a new EAC based method which is called Extended EAC, EEAC, is applied for constructing the co-association matrix from the subset of clusters. Employing this new cluster validation criterion, the obtained ensemble is evaluated on some well-known and standard data sets. The empirical studies show promising results for the ensemble obtained using the proposed criterion comparing with the ensemble obtained using the standard clusters validation criterion.
Document type :
Conference papers
Complete list of metadata
Cited literature [12 references]  Display  Hide  Download
https://hal.inria.fr/hal-01571447
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Wednesday, August 2, 2017 - 4:21:57 PM
Last modification on : Thursday, March 5, 2020 - 5:41:56 PM
File
978-3-642-23960-1_14_Chapter.p...
Identifiers
Citation
Hosein Alizadeh, Behrouz Minaei, Hamid Parvin. A New Criterion for Clusters Validation. 12th Engineering Applications of Neural Networks (EANN 2011) and 7th Artificial Intelligence Applications and Innovations (AIAI), Sep 2011, Corfu, Greece. pp.110-115, ⟨10.1007/978-3-642-23960-1_14⟩. ⟨hal-01571447⟩
Share
Metrics
Record views
100
Files downloads
96
