Conference papers
A Generalized Fuzzy-Rough Set Application for Forest Fire Risk Estimation Feature Reduction
Abstract : This paper aims in the reduction of data attributes of a fuzzy-set based system for the estimation of forest fire risk in Greece, with the use of rough-set theory. The aim is to get as good results as possible with the use of the minimum amount of data attributes possible. Data manipulation for this project is done in MS-Access. The resulting data table is inserted into Matlab in order to be fuzzified. The final result of this clustering is inserted into Rossetta, which is a Rough set exploration software, in order to estimate the reducts. The risk estimation is recalculated with the use of the reduct set in order to measure the accuracy of the final minimum attribute set. Nine forest fire risk factors were taken into consideration for the purpose of this paper and the Greek terrain was separated into smaller areas, each concerning a different Greek forest department.
Document type :
Conference papers
Complete list of metadata
Cited literature [12 references]  Display  Hide  Download
https://hal.inria.fr/hal-01571458
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Wednesday, August 2, 2017 - 4:22:05 PM
Last modification on : Thursday, March 5, 2020 - 5:42:29 PM
File
978-3-642-23960-1_40_Chapter.p...
Identifiers
Citation
T. Tsataltzinos, L. Iliadis, S. Spartalis. A Generalized Fuzzy-Rough Set Application for Forest Fire Risk Estimation Feature Reduction. 12th Engineering Applications of Neural Networks (EANN 2011) and 7th Artificial Intelligence Applications and Innovations (AIAI), Sep 2011, Corfu, Greece. pp.332-341, ⟨10.1007/978-3-642-23960-1_40⟩. ⟨hal-01571458⟩
Share
Metrics
Record views
208
Files downloads
73
