Modelling Nonlinear Responses of Resonance Sensors in Pressure Garment Application - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Timo Salpavaara
  • Fonction : Auteur
  • PersonId : 1014222
Pekka Kumpulainen
  • Fonction : Auteur
  • PersonId : 1014048
Information on the applied pressure is critical to the pressure garment treatment. The use of the passive resonance sensors would be significant improvement to existing systems. These sensors have nonlinear response and thus require nonlinear regression methods. In this paper we compare three nonlinear modelling methods: Sugeno type fuzzy inference system, support vector regression and multilayer perception networks. According to the results, all the tested methods are adequate for modelling an individual sensor. The used methods also give promising results when they are used to model responses of multiple sensors.
978-3-642-23960-1_49_Chapter.pdf (328.2 Ko) Télécharger le fichier
hal-01571487 , version 1 (02-08-2017)
Paternité
Timo Salpavaara, Pekka Kumpulainen. Modelling Nonlinear Responses of Resonance Sensors in Pressure Garment Application. 12th Engineering Applications of Neural Networks (EANN 2011) and 7th Artificial Intelligence Applications and Innovations (AIAI), Sep 2011, Corfu, Greece. pp.420-429, ⟨10.1007/978-3-642-23960-1_49⟩. ⟨hal-01571487⟩
50 Consultations
57 Téléchargements
