A Comparison of Venn Machine with Platt’s Method in Probabilistic Outputs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The main aim of this paper is to compare the results of several methods of prediction with confidence. In particular we compare the results of Venn Machine with Platt’s Method of estimating confidence. The results are presented and discussed.
978-3-642-23960-1_56_Chapter.pdf (239.37 Ko) Télécharger le fichier
hal-01571489 , version 1 (02-08-2017)
Paternité
Chenzhe Zhou, Ilia Nouretdinov, Zhiyuan Luo, Dmitry Adamskiy, Luke Randell, et al.. A Comparison of Venn Machine with Platt’s Method in Probabilistic Outputs. 12th Engineering Applications of Neural Networks (EANN 2011) and 7th Artificial Intelligence Applications and Innovations (AIAI), Sep 2011, Corfu, Greece. pp.483-490, ⟨10.1007/978-3-642-23960-1_56⟩. ⟨hal-01571489⟩
55 Consultations
99 Téléchargements
