A Comparison of Venn Machine with Platt’s Method in Probabilistic Outputs
The main aim of this paper is to compare the results of several methods of prediction with confidence. In particular we compare the results of Venn Machine with Platt’s Method of estimating confidence. The results are presented and discussed.
Informatique [cs]
