Feature Selection by Conformal Predictor - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this work we consider the problem of feature selection in the context of conformal prediction. Unlike many conventional machine learning methods, conformal prediction allows to supply individual predictions with valid measure of confidence. The main idea is to use confidence measures as an indicator of usefulness of different features: we check how many features are enough to reach desirable average level of confidence. The method has been applied to abdominal pain data set. The results are discussed.
978-3-642-23960-1_51_Chapter.pdf (83.36 Ko) Télécharger le fichier
hal-01571493 , version 1 (02-08-2017)
Paternité
Meng Yang, Ilia Nouretdinov, Zhiyuan Luo, Alex Gammerman. Feature Selection by Conformal Predictor. 12th Engineering Applications of Neural Networks (EANN 2011) and 7th Artificial Intelligence Applications and Innovations (AIAI), Sep 2011, Corfu, Greece. pp.439-448, ⟨10.1007/978-3-642-23960-1_51⟩. ⟨hal-01571493⟩
211 Consultations
82 Téléchargements
