Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, EpiSciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Abstract : Assuring compliant business processes is an important task of business process management, which is commonly supported by the use of business process models. As every compliance rule corresponds with a typical structure, the detection of those corresponds to a pattern matching problem. More specifically, we encounter the problem of subgraph isomorphism. In this paper we propose an automatic business process compliance checking approach that relies on a subgraph isomorphism algorithm and that is suitable for process models in general. As common subgraph isomorphism is a problem that can only be solved in exponential time, we use an algorithm that simplifies the problem through pre-processing. This makes the isomorphism solvable in polynomial time. With the approach, we aim at supporting decision makers in business process compliance management.
https://hal.inria.fr/hal-01571720 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Thursday, August 3, 2017 - 2:33:53 PM Last modification on : Wednesday, March 9, 2022 - 11:52:12 AM
Jörg Becker, Philipp Bergener, Dominic Breuker, Patrick Delfmann, Mathias Eggert. An Efficient Business Process Compliance Checking Approach. Governance and Sustainability in Information Systems: Managing the Transfer and Diffusion of IT (Working conference), Sep 2011, Hamburg, Germany. pp.282-287, ⟨10.1007/978-3-642-24148-2_19⟩. ⟨hal-01571720⟩
