New interface
Reports (Research report)
Residual distribution advection schemes in Telemac
Abstract : This report gives an overview of the different implementations of residual distribution schemes for the advection equation in Telemac (www.opentelemac.org). The formulations considered are obtained starting from the predictor-corrector method initially proposed in (Ricchiuto et Abgrall, JCP 2010). Several iteration techniques (NERD, LIPS and ERIA) are proposed and tested in terms of accuracy and efficiency. The basic idea of NERD is a transfer of fluxes done segment by segment, surprisingly this results in an unconditional stability. LIPS is based upon a local implicitation coefficient, ERIA inspires from NERD and treats the fluxes triangle by triangle. The main advances are the low numerical diffusion coupled with an unconditional stability that allows to deal with shallow or even dry zones in a computational domain.
Document type :
Complete list of metadata
Cited literature [7 references]  Display  Hide  Download
https://hal.inria.fr/hal-01571827
Contributor : Mario Ricchiuto Connect in order to contact the contributor
Submitted on : Saturday, August 5, 2017 - 3:13:36 PM
Last modification on : Wednesday, October 26, 2022 - 8:15:14 AM
File
rr9087.pdf
Identifiers
  • HAL Id : hal-01571827, version 2
Citation
Jean-Michel Hervouet, Sara Pavan, Mario Ricchiuto. Residual distribution advection schemes in Telemac. [Research Report] RR-9087, Inria Bordeaux Sud-Ouest. 2017, pp.70. ⟨hal-01571827v2⟩
Share
Metrics
Record views
555
Files downloads
371
