HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Image-based UAV localization using Interval Methods
Ide-Flore Kenmogne 1 Vincent Drevelle 1 Eric Marchand 1
1 Lagadic - Visual servoing in robotics, computer vision, and augmented reality
CRISAM - Inria Sophia Antipolis - Méditerranée , Inria Rennes – Bretagne Atlantique , IRISA-D5 - SIGNAUX ET IMAGES NUMÉRIQUES, ROBOTIQUE
Abstract : This paper proposes an image-based localization method that enables to estimate a bounded domain of the pose of an unmanned aerial vehicle (UAV) from uncertain measurements of known landmarks in the image. The approach computes a domain that should contain the actual robot pose, assuming bounded image measurement errors and landmark position uncertainty. It relies on interval analysis and constraint propagation techniques to rigorously back-propagate the errors through the non-linear observation model. Attitude information from onboard sensors is merged with image observations to reduce the pose uncertainty domain, along with prediction based on velocity measurements. As tracking landmarks in the image is prone to errors, the proposed method also enable fault detection from measurement inconsistencies. This method is tested using a quadcopter UAV with an onboard camera.
Document type :
Conference papers
Complete list of metadata
Cited literature [19 references]  Display  Hide  Download
https://hal.inria.fr/hal-01572369
Contributor : Eric Marchand Connect in order to contact the contributor
Submitted on : Monday, August 7, 2017 - 10:30:30 AM
Last modification on : Friday, April 8, 2022 - 4:04:03 PM
File
IROS17_1106_FI.pdf
Identifiers
  • HAL Id : hal-01572369, version 1
Citation
Ide-Flore Kenmogne, Vincent Drevelle, Eric Marchand. Image-based UAV localization using Interval Methods. IROS 2017 - IEEE/RSJ International Conference on Intelligent Robots and Systems, Sep 2017, Vancouver, Canada. pp.5285-5291. ⟨hal-01572369⟩
Share
Metrics
Record views
230
Files downloads
327
