Modeling an Agile Enterprise: Reconciling Systems and Process Thinking - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ilia Bider
Gene Bellinger
  • Fonction : Auteur
  • PersonId : 1014410
Selection of an enterprise modeling paradigm depends on the practical task the modeling project is trying to achieve. For example, modeling in the frame of Enterprise Architecture paradigm is, usually, aimed at alignment of the enterprise components, such as mission, vision, business processes, services and IT systems. Modeling in the frame of Business Process Management is aimed at process improvement/optimization, and modeling in the Systems Thinking paradigm is aimed at getting a holistic view on the dynamic behavior of the enterprise. This paper suggests a new approach to enterprise modeling that combine these approaches in order to reveal and improve enterprise agility. It is based on the systemic view of business processes, and it presents an enterprise as a three-layered model consisting of assets, sensors and business process instances. Elements of this model can be recursively decomposed, which allows for different levels of details when modeling an enterprise.
978-3-642-24849-8_18_Chapter.pdf (303.46 Ko) Télécharger le fichier
hal-01572397 , version 1 (07-08-2017)
Paternité
Ilia Bider, Gene Bellinger, Erik Perjons. Modeling an Agile Enterprise: Reconciling Systems and Process Thinking. 4th Practice of Enterprise Modeling (PoEM), Nov 2011, Oslo, Norway. pp.238-252, ⟨10.1007/978-3-642-24849-8_18⟩. ⟨hal-01572397⟩
397 Consultations
177 Téléchargements
