Abstract : In the paper an approach to developing a use-cases benchmark is presented. The benchmark itself is a referential use-case-based requirements specification, which has a typical profile observed in real projects. To obtain this profile an extensive analysis of 432 use cases coming from 11 projects was performed. Because the developed specification represents those found in real projects, it might be used in order to present, test, and verify methods and tools for use-case analysis. This is especially important because industrial specifications are in most cases confident, and they might not be used by researchers who would like to replicate studies performed by their colleagues.
https://hal.inria.fr/hal-01572532 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Monday, August 7, 2017 - 4:51:10 PM Last modification on : Thursday, November 5, 2020 - 11:46:02 AM
Bartosz Alchimowicz, Jakub Jurkiewicz, Jerzy Nawrocki, Mirosław Ochodek. Towards Use-Cases Benchmark. 3rd Central and East European Conference on Software Engineering Techniques (CEESET), Oct 2008, Brno, Czech Republic. pp.20-33, ⟨10.1007/978-3-642-22386-0_2⟩. ⟨hal-01572532⟩
