Conference papers
SMA—The Smyle Modeling Approach
Abstract : This paper introduces the model-based software development methodology SMA—the Smyle Modeling Approach—which is centered around Smyle, a dedicated learning procedure to support engineers to interactively obtain design models from requirements, characterized as either being desired (positive) or unwanted (negative) system behavior. The learning approach is complemented by scenario patterns where the engineer can specify clearly desired or unwanted behavior. This way, user interaction is reduced to the interesting scenarios limiting the design effort considerably. In SMA, the learning phase is complemented by an effective analysis phase that allows for detecting design flaws at an early design stage. This paper describes the approach and reports on first practical experiences.
Document type :
Conference papers
Complete list of metadata
Cited literature [29 references]  Display  Hide  Download
https://hal.inria.fr/hal-01572543
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Monday, August 7, 2017 - 4:51:18 PM
Last modification on : Thursday, January 6, 2022 - 11:38:04 AM
File
978-3-642-22386-0_8_Chapter.pd...
Identifiers
Citation
Benedikt Bollig, Joost-Pieter Katoen, Carsten Kern, Martin Leucker. SMA—The Smyle Modeling Approach. 3rd Central and East European Conference on Software Engineering Techniques (CEESET), Oct 2008, Brno, Czech Republic. pp.103-117, ⟨10.1007/978-3-642-22386-0_8⟩. ⟨hal-01572543⟩
Share
Metrics
Record views
102
Files downloads
72
