Abstract : By describing business processes in BPEL (Business Process Execution Language) one can make them executable. Then a problem arises how to assure that some non-functional requirements concerning e.g. performance of these processes, are met. In the paper a transformational approach to design of business processes is presented. To check equivalence of business processes resulting from the transformations, a BPEL description is converted to Process Algebra (Lotos version) and model-checking techniques are applied. The paper contains also an example of applying the proposed approach in a real-life situation.
https://hal.inria.fr/hal-01572550 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Monday, August 7, 2017 - 4:51:23 PM Last modification on : Monday, August 7, 2017 - 4:53:37 PM
Andrzej Ratkowski, Andrzej Zalewski. Transformational Design of Business Processes for SOA. 3rd Central and East European Conference on Software Engineering Techniques (CEESET), Oct 2008, Brno, Czech Republic. pp.76-90, ⟨10.1007/978-3-642-22386-0_6⟩. ⟨hal-01572550⟩
