Enhancing Use Cases with Screen Designs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Łukasz Olek
  • Fonction : Auteur
  • PersonId : 1014471
Mirosław Ochodek
  • Fonction : Auteur
  • PersonId : 1014432
This paper presents a language called ScreenSpec that can be used to specify screens at requirements elicitation phase. ScreenSpec was successfully applied in 8 real projects. It is very effective: average time needed to specify a screen is 2 minutes, and takes an hour to become proficient in using it. Visual representation generated from ScreenSpec can be attached to requirements specification (e.g. as adornments to use cases).
978-3-642-22386-0_4_Chapter.pdf (593.23 Ko) Télécharger le fichier
hal-01572553 , version 1 (07-08-2017)
Paternité
Łukasz Olek, Jerzy Nawrocki, Mirosław Ochodek. Enhancing Use Cases with Screen Designs. 3rd Central and East European Conference on Software Engineering Techniques (CEESET), Oct 2008, Brno, Czech Republic. pp.48-61, ⟨10.1007/978-3-642-22386-0_4⟩. ⟨hal-01572553⟩
81 Consultations
80 Téléchargements
