Fault Based Cryptanalysis of the Advanced Encryption Standard (AES), Lecture Notes in Computer Science, vol.2742, pp.162-181, 2003. ,
DOI : 10.1007/978-3-540-45126-6_12
Differential Fault Analysis on A.E.S, Applied Cryptography and Network Security ? ACNS 2003, pp.293-306, 2003. ,
DOI : 10.1007/978-3-540-45203-4_23
DFA on AES, International Conference Advanced Encryption Standard ? AES 2004, pp.27-41, 2004. ,
DOI : 10.1007/11506447_4
Piret and Quisquater's DFA on AES revisited, Cryptology ePrint Archive Report, vol.440, 2010. ,
New Differential Fault Analysis on AES Key Schedule: Two Faults Are Enough, Smart Card Research and Advanced Applications ? CARDIS, pp.48-60, 2008. ,
DOI : 10.1109/FDTC.2007.13
Deal ? a 128-bit block cipher, 1998. ,
An information theoretic perspective on the differential fault analysis against aes, Cryptology ePrint Archive, 2010. ,
A Generalized Method of Differential Fault Attack Against AES Cryptosystem, Cryptographic Hardware and Embedded Systems ? CHES 2006, pp.91-100, 2006. ,
DOI : 10.1007/11894063_8
An Improved Fault Based Attack of the Advanced Encryption Standard, Progress in Cryptology ? AFRICACRYPT 2009, pp.421-434, 2009. ,
Differentially uniform mappings for cryptography, Advances in Cryptology ? EUROCRYPT '93, pp.55-64, 1993. ,
DOI : 10.1007/3-540-48285-7_6
A Differential Fault Attack Technique against SPN Structures, with Application to the AES and Khazad, Cryptographic Hardware and Embedded Systems ? CHES 2003, pp.77-88, 2003. ,
DOI : 10.1007/978-3-540-45238-6_7
DFA Mechanism on the AES Key Schedule, Workshop on Fault Diagnosis and Tolerance in Cryptography (FDTC 2007), pp.62-72, 2007. ,
