Semantic image segmentation with deep convolutional nets and fully connected CRFs, ICLR, 2015. ,
DOI : 10.1109/tpami.2017.2699184
URL : http://arxiv.org/abs/1606.00915
The Pascal Visual Object Classes (VOC) Challenge, International Journal of Computer Vision, vol.73, issue.2, pp.303-338, 2010. ,
DOI : 10.1371/journal.pcbi.0040027
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.167.6629
Bottom-Up Segmentation for Top-Down Detection, 2013 IEEE Conference on Computer Vision and Pattern Recognition ,
DOI : 10.1109/CVPR.2013.423
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.296.7948
DSSD: Deconvolutional single shot detector, p.3, 2017. ,
Rich Feature Hierarchies for Accurate Object Detection and Semantic Segmentation, 2014 IEEE Conference on Computer Vision and Pattern Recognition, 2014. ,
DOI : 10.1109/CVPR.2014.81
URL : http://arxiv.org/abs/1311.2524
Region-based segmentation and object detection, NIPS, 2009. ,
Semantic contours from inverse detectors, 2011 International Conference on Computer Vision, 2011. ,
DOI : 10.1109/ICCV.2011.6126343
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.221.801
Deep Residual Learning for Image Recognition, 2016 IEEE Conference on Computer Vision and Pattern Recognition (CVPR), 2005. ,
DOI : 10.1109/CVPR.2016.90
URL : http://arxiv.org/abs/1512.03385
Adam: A method for stochastic optimization, ICLR, 2015. ,
UberNet: Training a universal convolutional neural network for low-, mid-, and high-level vision using diverse datasets and limited memory, CVPR, 2017. 1 ,
Backpropagation Applied to Handwritten Zip Code Recognition, Neural Computation, vol.1, issue.4, pp.541-551, 1989. ,
DOI : 10.1007/BF00133697
Object detection via region-based fully convolutional networks, NIPS, 2007. ,
Feature pyramid networks for object detection, CVPR, 2017. ,
SSD: Single Shot MultiBox Detector, ECCV, 2007. ,
DOI : 10.1109/CVPR.2008.4587597
URL : http://arxiv.org/pdf/1512.02325
Fully convolutional networks for semantic segmentation, 2015 IEEE Conference on Computer Vision and Pattern Recognition (CVPR), 2015. ,
DOI : 10.1109/CVPR.2015.7298965
URL : http://arxiv.org/pdf/1411.4038
The Role of Context for Object Detection and Semantic Segmentation in the Wild, 2014 IEEE Conference on Computer Vision and Pattern Recognition, 2014. ,
DOI : 10.1109/CVPR.2014.119
Stacked Hourglass Networks for Human Pose Estimation, ECCV, 2007. ,
DOI : 10.1109/ICCV.2015.178
URL : http://arxiv.org/abs/1603.06937
Learning Deconvolution Network for Semantic Segmentation, 2015 IEEE International Conference on Computer Vision (ICCV), p.3 ,
URL : http://arxiv.org/abs/1505.04366
Weakly-and Semi-Supervised Learning of a Deep Convolutional Network for Semantic Image Segmentation, 2015 IEEE International Conference on Computer Vision (ICCV), 2015. ,
DOI : 10.1109/ICCV.2015.203
Learning to Refine Object Segments, ECCV, 2016. ,
DOI : 10.5244/C.30.15
URL : http://arxiv.org/abs/1603.08695
You Only Look Once: Unified, Real-Time Object Detection, 2016 IEEE Conference on Computer Vision and Pattern Recognition (CVPR), 2007. ,
DOI : 10.1109/CVPR.2016.91
URL : http://arxiv.org/abs/1506.02640
YOLO9000: better, faster, stronger. arXiv preprint, 2016. ,
Faster R-CNN: Towards Real-Time Object Detection with Region Proposal Networks, NIPS, 2015. 1, p.7 ,
DOI : 10.1109/TPAMI.2016.2577031
URL : http://arxiv.org/abs/1506.01497
U-Net: Convolutional Networks for Biomedical Image Segmentation, p.7, 2015. ,
DOI : 10.1007/978-3-319-24574-4_28
URL : http://arxiv.org/abs/1505.04597
Very deep convolutional networks for large-scale image recognition, 2003. ,
Multinet: Real-time joint semantic reasoning for autonomous driving ,
Describing the scene as a whole: Joint object detection, scene classification and semantic segmentation, CVPR, 2012. 1 ,
