Core Network Function Placement in Mobile Networks
Abstract : An isolated base station is a base station having no connection to a traditional core network. To provide services to users, an isolated base station is co-located with an entity providing the same functionalities as the traditional core network, referred to as Local EPC. In order to cover wider areas, several base stations are interconnected, forming a network that should be served by a single Local EPC. In this work, we tackle the Local EPC placement problem in the network, to determine with which of the base stations the Local EPC must be co-located. We propose a novel centrality metric, flow centrality, which measures the capacity of a node to receive the total amount of flows in the network. We show that co-locating the Local EPC with the base station having the maximum flow centrality maximizes the total amount of traffic the Local EPC can receive from all base stations, under certain capacity and load distribution constraints. We compare the flow centrality to other state of the art centrality metrics, and emphasize its advantages.
Type de document :
Communication dans un congrès
PIMRC 2017 - IEEE International Symposium on Personal, Indoor and Mobile Radio Communications, Oct 2017, Montreal, Canada. pp.5, 〈http://pimrc2017.ieee-pimrc.org/〉
Liste complète des métadonnées
Littérature citée [12 références]  Voir  Masquer  Télécharger
https://hal.archives-ouvertes.fr/hal-01573380
Contributeur : Jad Oueis <>
Soumis le : mercredi 9 août 2017 - 12:41:29
Dernière modification le : samedi 27 octobre 2018 - 01:20:01
Fichier
PID4943879.pdf
Fichiers produits par l'(les) auteur(s)
  • HAL Id : hal-01573380, version 1
Collections
Citation
Jad Oueis, Vania Conan, Damien Lavaux, Razvan Stanica, Fabrice Valois. Core Network Function Placement in Mobile Networks. PIMRC 2017 - IEEE International Symposium on Personal, Indoor and Mobile Radio Communications, Oct 2017, Montreal, Canada. pp.5, 〈http://pimrc2017.ieee-pimrc.org/〉. 〈hal-01573380〉
Métriques
Consultations de la notice
263
Téléchargements de fichiers
407
