Spatially regularized multifractal analysis for fMRI Data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Scale-free dynamics is nowadays a massively used paradigm to model infraslow macroscopic brain activity. Mul-tifractal analysis is becoming the standard tool to characterize scale-free dynamics. It is commonly used on various modalities of neuroimaging data to evaluate whether arrhythmic fluctuations in ongoing or evoked brain activity are related to patholo-gies (Alzheimer, epilepsy) or task performance. The success of multifractal analysis in neurosciences remains however so far contrasted: While it lead to relevant findings on M/EEG data, less clear impact was shown when applied to fMRI data. This is mostly due to their poor time resolution and very short duration as well as to the fact that analysis remains performed voxelwise. To take advantage of the large amount of voxels recorded jointly in fMRI, the present contribution proposes the use of a recently introduced Bayesian formalism for multifractal analysis, that regularizes the estimation of the multifractality parameter of a given voxel using information from neighbor voxels. The benefits of this regularized multifractal analysis are illustrated by comparison against classical multifractal analysis on fMRI data collected on one subject, at rest and during a working memory task: Though not yet statistically significant, increased multifractality is observed in task-negative and task-positive networks, respectively.
EMBC2017_fMRIc2_revised_post.pdf (985.27 Ko) Télécharger le fichier
hal-01574216 , version 1 (11-08-2017)
  • HAL Id : hal-01574216 , version 1
Philippe Ciuciu, Herwig Wendt, Sébastien Combrexelle, Patrice Abry. Spatially regularized multifractal analysis for fMRI Data. EMBC’17 - 39th International Conference of the IEEE Engineering in Medicine and Biology Society, Kwang Suk Park, Jul 2017, Jeju, South Korea. pp.4. ⟨hal-01574216⟩
488 Consultations
171 Téléchargements
