Sobolev regularity for first order Mean Field Games - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
In this paper we obtain Sobolev estimates for weak solutions of first oder variational Mean Field Game systems with coupling terms that are local function of the density variable. Under some coercivity condition on the coupling, we obtain first order Sobolev estimates for the density variable, while under similar coercivity condition on the Hamiltonian we obtain second order Sobolev estimates for the value function. These results are valid both for stationary and time-dependent problems. In the latter case the estimates are fully global in time, thus we resolve a question which was left open in [PS17]. Our methods apply to a large class of Hamiltonians and coupling functions.
FINAL_jameson_alpar.pdf (261.96 Ko) Télécharger le fichier
hal-01575277 , version 1 (18-08-2017)
P. Jameson Graber, Alpár R. Mészáros. Sobolev regularity for first order Mean Field Games. 2017. ⟨hal-01575277⟩
Collections
TDS-MACS
35 Consultations
67 Téléchargements
