Symbolic Simulation of Dataflow Synchronous Programs with Timers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The synchronous language Lustre and its descendants have long been used to program and model discrete controllers. Recent work shows how to mix discrete and continuous elements in a Lustre-like language called Zélus. The resulting hybrid programs are deterministic and can be simulated with a numerical solver. In this article, we focus on a subset of hybrid programs where continuous behaviors are expressed using timers, nondeterministic guards, and invariants, as in Timed Safety Automata. We propose a source-to-source compilation pass to generate discrete code that, coupled with standard operations on Difference-Bound Matrices, produces symbolic traces that each represent a set of concrete traces.
paper.pdf (347.04 Ko) Télécharger le fichier
hal-01575621 , version 1 (21-08-2017)
hal-01575621 , version 2 (19-09-2017)
hal-01575621 , version 3 (01-12-2017)
hal-01575621 , version 4 (11-01-2019)
  • HAL Id : hal-01575621 , version 3
Guillaume Baudart, Timothy Bourke, Marc Pouzet. Symbolic Simulation of Dataflow Synchronous Programs with Timers. 12th Forum on Specification and Design Languages (FDL 2017), Electronic Chips & System Design Initiative (ECSI), Sep 2017, Vérone, Italy. ⟨hal-01575621v3⟩
407 Consultations
335 Téléchargements
