Nonlinear total variation based noise removal algorithms, Physica D : Nonlinear Phenomena, vol.60, pp.259-268, 1992. ,
DCT image denoising: a simple and effective image denoising algorithm, Image Processing On Line, vol.1, 2011. ,
DOI : 10.5201/ipol.2011.ys-dct
URL : http://doi.org/10.5201/ipol.2011.ys-dct
Fields of Experts, International Journal of Computer Vision, vol.27, issue.2, pp.205-229, 2009. ,
DOI : 10.1007/s11263-005-4635-4
A Tour of Modern Image Filtering: New Insights and Methods, Both Practical and Theoretical, IEEE Signal Processing Magazine, vol.30, issue.1, pp.106-128, 2013. ,
DOI : 10.1109/MSP.2011.2179329
Image Denoising Via Sparse and Redundant Representations Over Learned Dictionaries, IEEE Transactions on Image Processing, vol.15, issue.12, pp.3736-3745, 2006. ,
DOI : 10.1109/TIP.2006.881969
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.109.6477
Non-local sparse models for image restoration, 2009 IEEE 12th International Conference on Computer Vision, pp.2272-2279, 2009. ,
DOI : 10.1109/ICCV.2009.5459452
A Review of Image Denoising Algorithms, with a New One, Multiscale Modeling & Simulation, vol.4, issue.2, pp.490-530, 2005. ,
DOI : 10.1137/040616024
URL : https://hal.archives-ouvertes.fr/hal-00271141
Is Denoising Dead?, IEEE Transactions on Image Processing, vol.19, issue.4, pp.895-911, 2010. ,
DOI : 10.1109/TIP.2009.2037087
Patch Complexity, Finite Pixel Correlations and Optimal Denoising, Eur. Conf. Comp. Vis. (ECCV'12), pp.73-86, 2012. ,
DOI : 10.1007/978-3-642-33715-4_6
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.259.8316
Suboptimality of nonlocal means for images with sharp edges, Applied and Computational Harmonic Analysis, vol.33, issue.3, pp.370-387, 2012. ,
DOI : 10.1016/j.acha.2012.02.003
Image Denoising by Sparse 3-D Transform-Domain Collaborative Filtering, IEEE Transactions on Image Processing, vol.16, issue.8, pp.2080-2095, 2007. ,
DOI : 10.1109/TIP.2007.901238
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.219.5398
From learning models of natural image patches to whole image restoration, 2011 International Conference on Computer Vision, pp.479-486, 2011. ,
DOI : 10.1109/ICCV.2011.6126278
Implementation of the "Non-Local Bayes" (NL-Bayes) Image Denoising Algorithm, Image Processing On Line, vol.3, pp.1-42, 2013. ,
DOI : 10.5201/ipol.2013.16
PEWA : Patch-based exponentially weighted aggregation for image denoising, Neural Information Processing Systems (NIPS'14), pp.2150-2158, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01103358
Patch-Based Near-Optimal Image Denoising, IEEE Transactions on Image Processing, vol.21, issue.4, pp.1635-1649, 2012. ,
DOI : 10.1109/TIP.2011.2172799
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.220.9390
SURE Guided Gaussian Mixture Image Denoising, SIAM Journal on Imaging Sciences, vol.6, issue.2, pp.999-1034, 2013. ,
DOI : 10.1137/120901131
URL : https://hal.archives-ouvertes.fr/hal-00785334
Digital picture processing. An introduction, 1985. ,
Bilateral filtering for gray and color images, Sixth International Conference on Computer Vision (IEEE Cat. No.98CH36271), pp.839-846, 1998. ,
DOI : 10.1109/ICCV.1998.710815
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.126.2091
A two-stage denoising filter: The preprocessed Yaroslavsky filter, 2012 IEEE Statistical Signal Processing Workshop (SSP), pp.464-467, 2012. ,
DOI : 10.1109/SSP.2012.6319733
URL : http://arxiv.org/abs/1208.6516
Adaptive weights smoothing with applications to image restoration, Journal of the Royal Statistical Society: Series B (Statistical Methodology), vol.62, issue.2, pp.335-354, 2000. ,
DOI : 10.1111/1467-9868.00235
Image denoising : pointwise adaptive approach, Ann. Statistics, vol.31, issue.1, pp.30-57, 2003. ,
Propagation-Separation Approach for Local Likelihood Estimation, Probability Theory and Related Fields, vol.135, issue.3, pp.335-362, 2006. ,
DOI : 10.1007/s00440-005-0464-1
Optimal Spatial Adaptation for Patch-Based Image Denoising, IEEE Transactions on Image Processing, vol.15, issue.10, pp.2866-2878, 2006. ,
DOI : 10.1109/TIP.2006.877529
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.228.6155
Bayesian Non-local Means Filter, Image Redundancy and Adaptive Dictionaries for Noise Removal, Int. Conf. on Scale Space and Variational Methods (SSVM'07), pp.520-532, 2007. ,
DOI : 10.1007/978-3-540-72823-8_45
URL : https://hal.archives-ouvertes.fr/hal-00645444
Empirical Bayes least squares estimation without an explicit prior, Courant Institute of Mathematical Sciences, 2007. ,
Local Adaptivity to Variable Smoothness for Exemplar-Based Image Regularization and Representation, International Journal of Computer Vision, vol.27, issue.2, pp.45-69, 2008. ,
DOI : 10.1007/978-1-4612-0845-7
An improved non-local denoising algorithm, Int. Workshop Local and Non-Local Approximation in Image Processing, pp.1-14, 2008. ,
Robust NL-Means Filter With Optimal Pixel-Wise Smoothing Parameter for Statistical Image Denoising, IEEE Transactions on Signal Processing, vol.57, issue.5, pp.1703-1716, 2009. ,
DOI : 10.1109/TSP.2008.2011832
Iterative Weighted Maximum Likelihood Denoising With Probabilistic Patch-Based Weights, IEEE Transactions on Image Processing, vol.18, issue.12, pp.2661-2672, 2009. ,
DOI : 10.1109/TIP.2009.2029593
URL : https://hal.archives-ouvertes.fr/ujm-00431266
SURE-Based Non-Local Means, IEEE Signal Processing Letters, vol.16, issue.11, pp.973-976, 2009. ,
DOI : 10.1109/LSP.2009.2027669
Generalised Nonlocal Image Smoothing, International Journal of Computer Vision, vol.9, issue.4, pp.62-87, 2010. ,
DOI : 10.1007/978-1-4612-4838-5
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.299.7573
From Local Kernel to Nonlocal Multiple-Model Image Denoising, International Journal of Computer Vision, vol.11, issue.1, pp.1-32, 2010. ,
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.161.3636
Image Recovery via Nonlocal Operators, Journal of Scientific Computing, vol.60, issue.3, pp.185-197, 2010. ,
DOI : 10.1007/978-3-642-81929-2
Total Variation as a Local Filter, SIAM Journal on Imaging Sciences, vol.4, issue.2, pp.651-694, 2011. ,
DOI : 10.1137/100785855
URL : https://hal.archives-ouvertes.fr/hal-00457763
Non-local Methods with Shape-Adaptive Patches (NLM-SAP), Journal of Mathematical Imaging and Vision, vol.13, issue.4, pp.103-120, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00536723
Posterior Expectation of the Total Variation Model: Properties and Experiments, SIAM Journal on Imaging Sciences, vol.6, issue.4, pp.2640-2684, 2013. ,
DOI : 10.1137/120902276
URL : https://hal.archives-ouvertes.fr/hal-00764175
Image Processing Using Smooth Ordering of its Patches, IEEE Transactions on Image Processing, vol.22, issue.7, pp.2764-2774, 2013. ,
DOI : 10.1109/TIP.2013.2257813
URL : http://arxiv.org/abs/1210.3832
Adaptive Regularization of the NL-Means: Application to Image and Video Denoising, IEEE Transactions on Image Processing, vol.23, issue.8, pp.3506-3521, 2014. ,
DOI : 10.1109/TIP.2014.2329448
URL : https://hal.archives-ouvertes.fr/hal-00854830
Patch reprojections for Non-Local methods, Signal Processing, vol.92, issue.2, pp.477-489, 2012. ,
DOI : 10.1016/j.sigpro.2011.08.011
A Bias-Variance Approach for the Nonlocal Means, SIAM Journal on Imaging Sciences, vol.4, issue.2, pp.760-788, 2011. ,
DOI : 10.1137/100790902
URL : https://hal.archives-ouvertes.fr/hal-00947885
A note on multi-image denoising, 2009 International Workshop on Local and Non-Local Approximation in Image Processing, pp.1-15, 2009. ,
DOI : 10.1109/LNLA.2009.5278408
A new method for removing mixed noises, Science China Information Sciences, vol.24, issue.10, pp.1-9, 2010. ,
DOI : 10.1109/83.503916
NL-Means and aggregation procedures, 2009 16th IEEE International Conference on Image Processing (ICIP), pp.2977-2980, 2009. ,
DOI : 10.1109/ICIP.2009.5414512
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.207.7
Linear Estimation for Approximately Linear Models, The Annals of Statistics, vol.6, issue.5, pp.1122-1137, 1978. ,
DOI : 10.1214/aos/1176344315
Extending the direct weight optimization approach, 2004. ,
Nonlinear system identification via direct weight optimization, Automatica, vol.41, issue.3, pp.475-490, 2005. ,
DOI : 10.1016/j.automatica.2004.11.010
URL : http://liu.diva-portal.org/smash/get/diva2:316912/FULLTEXT01
Direct weight optimization in statistical estimation and system identification, System Identification and Control Problems (SICPRO08), pp.27-67, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-01270360
Anisotropic nonlocal means denoising, Applied and Computational Harmonic Analysis, vol.35, issue.3, pp.452-482, 2013. ,
DOI : 10.1016/j.acha.2012.11.003
URL : http://arxiv.org/abs/1112.0311
Ideal spatial adaptation by wavelet shrinkage, Biometrika, vol.81, issue.3, pp.425-455, 1994. ,
DOI : 10.1093/biomet/81.3.425
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.124.5288
Non-Local Means Denoising, Image Processing On Line, vol.1, 2011. ,
DOI : 10.5201/ipol.2011.bcm_nlm
URL : http://doi.org/10.5201/ipol.2011.bcm_nlm
An optimized blockwise Non-Local means denoising filter for 3D Magnetic Resonance Images, IEEE Trans. Medical Imaging, vol.27, issue.4, pp.325-441, 2008. ,
Fast Noise Variance Estimation, Computer Vision and Image Understanding, vol.64, issue.2, pp.300-302, 1996. ,
DOI : 10.1006/cviu.1996.0060
Analysis and Extension of the Percentile Method, Estimating a Noise Curve from a Single Image, Image Processing On Line, vol.3, pp.332-359, 2013. ,
DOI : 10.5201/ipol.2013.90
Estimation of the Noise Level Function Based on a Nonparametric Detection of Homogeneous Image Regions, SIAM Journal on Imaging Sciences, vol.8, issue.4, pp.2622-2661, 2015. ,
DOI : 10.1137/15M1012682
URL : https://hal.archives-ouvertes.fr/hal-01138809
Unsupervised patch-based image regularization and representation, Eur. Conf. Comp. Vision (ECCV'06), pp.555-567, 2006. ,
On a Problem of Adaptive Estimation in Gaussian White Noise, Theory of Probability & Its Applications, vol.35, issue.3, pp.454-466, 1990. ,
DOI : 10.1137/1135065
Optimal spatial adaptation to inhomogeneous smoothness : an approach based on kernel estimates with variable bandwidth selectors, Annals of Statistics, vol.25, issue.3, pp.929-947, 1997. ,
Deblurring and Denoising of Images by Nonlocal Functionals, Multiscale Modeling & Simulation, vol.4, issue.4, pp.1091-1115, 2005. ,
DOI : 10.1137/050622249
On Two Parameters for Denoising With Non-Local Means, IEEE Signal Processing Letters, vol.17, issue.3, pp.269-272, 2010. ,
DOI : 10.1109/LSP.2009.2038954
Fast nonlocal filtering applied to electron cryomicroscopy, 2008 5th IEEE International Symposium on Biomedical Imaging: From Nano to Macro, pp.1331-1334, 2008. ,
DOI : 10.1109/ISBI.2008.4541250
Parameter-Free Fast Pixelwise Non-Local Means Denoising, Image Processing On Line, vol.4, pp.300-326, 2014. ,
DOI : 10.5201/ipol.2014.120
URL : https://hal.archives-ouvertes.fr/hal-01082258
Lagrange multipliers and optimality. SIAM review, pp.183-238, 1993. ,
DOI : 10.1137/1035044
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.161.7209
Optimization under constraints : theory and applications of nonlinear programming, 1971. ,
