Decoding fMRI activity in the time domain improves classification performance - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue NeuroImage Année : 2017
Most current functional Magnetic Resonance Imaging (fMRI) decoding analyses rely on statistical summaries of the data resulting from a deconvolution approach: each stimulation event is associated with a brain response. This standard approach leads to simple learning procedures, yet it is ill-suited for decoding events with short inter-stimulus intervals. In order to overcome this issue, we propose a novel framework that separates the spatial and temporal components of the prediction by decoding the fMRI time-series continuously, i.e. scan-by-scan. The stimulation events can then be identified through a deconvolution of the reconstructed time series. We show that this model performs as well as or better than standard approaches across several datasets, most notably in regimes with small inter-stimuli intervals (3 to 5s), while also offering predictions that are highly interpretable in the time domain. This opens the way toward analyzing datasets not normally thought of as suitable for decoding and makes it possible to run decoding on studies with reduced scan time.
main.pdf (5.5 Mo) Télécharger le fichier
activation_maps_dimmed-1_renamed.pdf (2.12 Mo) Télécharger le fichier
all_boxplot_labeled_balanced.pdf (38.2 Ko) Télécharger le fichier
all_boxplot_labeled_corrected2.pdf (25.95 Ko) Télécharger le fichier
gauthier_barplot_labeled2.pdf (16.24 Ko) Télécharger le fichier
gauthier_final.pdf (59.58 Ko) Télécharger le fichier
glm_image.pdf (67.28 Ko) Télécharger le fichier
main.bbl (8.86 Ko) Télécharger le fichier
main.log (28.63 Ko) Télécharger le fichier
main.tex (38.46 Ko) Télécharger le fichier
model.pdf (2.84 Mo) Télécharger le fichier
mrt_time_series_version3.pdf (44.24 Ko) Télécharger le fichier
nested_cross_validation.pdf (24.02 Ko) Télécharger le fichier
references_new.bib (39.97 Ko) Télécharger le fichier
single_simulation_boxplot_labeled.pdf (17.02 Ko) Télécharger le fichier
time_window_barplot.pdf (11.93 Ko) Télécharger le fichier
hal-01576641 , version 1 (25-08-2017)
João Loula, Gaël Varoquaux, Bertrand Thirion. Decoding fMRI activity in the time domain improves classification performance. NeuroImage, 2017, ⟨10.1016/j.neuroimage.2017.08.018⟩. ⟨hal-01576641⟩
557 Consultations
1115 Téléchargements
