On the Generation of Sampling Schemes for Magnetic Resonance Imaging, SIAM Journal on Imaging Sciences, vol.9, issue.4, 2016. ,
DOI : 10.1137/16M1059205
URL : https://hal.archives-ouvertes.fr/hal-01373758
Characterizing radial undersampling artifacts for cardiac applications Magnetic resonance in medicine 55, pp.396-403, 2006. ,
Projection reconstruction techniques for reduction of motion e×ects in MRI, Magnetic Resonance in Medicine, vol.282, pp.275-289, 1992. ,
Reduction of motion artifacts in cine MRI using variable-density spiral trajectories Magnetic resonance in medicine 37, pp.569-575, 1997. ,
k-t FOCUSS: A general compressed sensing framework for high resolution dynamic MRI, Magnetic Resonance in Medicine, vol.54, issue.1, pp.103-116, 2009. ,
DOI : 10.1002/mrm.21757
XD-GRASP: Golden-angle radial MRI with reconstruction of extra motion-state dimensions using compressed sensing, Magnetic resonance in medicine 75, pp.775-788, 2016. ,
DOI : 10.1148/radiol.12120826
Spiral Acquisition for High-Speed Anatomical Imaging at 7T, ISMRM 24th Annual Meeting & Exhibition, 2016. ,
A Projection Algorithm for Gradient Waveforms Design in Magnetic Resonance Imaging, IEEE transactions on medical imaging, vol.35, issue.9, pp.2026-2039, 2016. ,
Compressed Sensing in MRI: how the Maximum Undersampling Factor depends on the Image Size, ESMRMB 2016 Congress. ePoster n°127 ,
A Fast Iterative Shrinkage-Thresholding Algorithm for Linear Inverse Problems, SIAM Journal on Imaging Sciences, vol.2, issue.1, pp.183-202, 2009. ,
DOI : 10.1137/080716542
Using NFFT 3---A Software Library for Various Nonequispaced Fast Fourier Transforms, ACM Transactions on Mathematical Software, vol.36, issue.4, pp.36-37, 2009. ,
DOI : 10.1145/1555386.1555388
Image Quality Assessment: From Error Visibility to Structural Similarity, IEEE Transactions on Image Processing, vol.13, issue.4, pp.600-612, 2004. ,
DOI : 10.1109/TIP.2003.819861
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.11.2477
Gradient system characterization by impulse response measurements with a dynamic Òeld camera Magnetic resonance in medicine 69, pp.583-593, 2013. ,
