Vibration-based structural damage identification, Philosophical Transactions of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.359, issue.1778, pp.131-149, 1778. ,
DOI : 10.1098/rsta.2000.0717
Vibration Based Condition Monitoring: A Review, Structural Health Monitoring: An International Journal, vol.29, issue.4, pp.355-377, 2004. ,
DOI : 10.1016/S0029-8018(01)00077-4
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.118.3093
Vibration-based Damage Identification Methods: A Review and Comparative Study, Structural Health Monitoring: An International Journal, vol.292, issue.1, pp.83-111, 2011. ,
DOI : 10.1016/j.jsv.2005.07.035
An introduction to structural health monitoring, Philosophical Transactions of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.365, issue.1851, pp.303-315, 1851. ,
DOI : 10.1098/rsta.2006.1928
Vibration-based structural health monitoring using output-only measurements under changing environment, Mechanical Systems and Signal Processing, vol.22, issue.1, pp.34-56, 2008. ,
DOI : 10.1016/j.ymssp.2007.07.004
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.548.4795
Merging Sensor Data from Multiple Temperature Scenarios for Vibration Monitoring of Civil Structures, Structural Health Monitoring: An International Journal, vol.34, issue.1, pp.129-142, 2008. ,
DOI : 10.1016/S0022-460X(74)80355-X
Subspace-based damage detection under changes in the ambient excitation statistics, Mechanical Systems and Signal Processing, vol.45, issue.1, pp.207-224, 2014. ,
DOI : 10.1016/j.ymssp.2013.10.023
Structural health monitoring with statistical methods during progressive damage test of S101 Bridge, Engineering Structures, vol.69, pp.183-193, 2014. ,
DOI : 10.1016/j.engstruct.2014.03.010
On vibration-based damage detection by multivariate statistical techniques: Application to a long-span arch bridge, Structural Health Monitoring: An International Journal, vol.278, issue.3, pp.505-524, 2016. ,
DOI : 10.1016/j.jsv.2003.10.041
Civil structure condition assessment by FE model updating:, Finite Elements in Analysis and Design, vol.37, issue.10, pp.761-775, 2001. ,
DOI : 10.1016/S0168-874X(00)00071-8
Dealing with uncertainty in model updating for damage assessment: A review, Mechanical Systems and Signal Processing, vol.56, issue.57, pp.123-149, 2015. ,
DOI : 10.1016/j.ymssp.2014.11.001
Towards extraction of vibration-based damage indicators, Proc. 8th European Workshop on Structural Health Monitoring ,
URL : https://hal.archives-ouvertes.fr/hal-01344178
Statistical model-based damage localization: A combined subspace-based and substructuring approach, Structural Control and Health Monitoring, vol.44, issue.6, pp.857-875, 2008. ,
DOI : 10.1155/2007/69136
Fault detection, isolation and quantification from Gaussian residuals with application to structural damage diagnosis, Annual Reviews in Control, vol.42, pp.244-256, 2016. ,
DOI : 10.1016/j.arcontrol.2016.08.002
Load Vectors for Damage Localization, Journal of Engineering Mechanics, vol.128, issue.1, pp.7-14, 2002. ,
DOI : 10.1061/(ASCE)0733-9399(2002)128:1(7)
URL : https://hal.archives-ouvertes.fr/hal-00824106
Load Vectors for Damage Location in Systems Identified from Operational Loads, Journal of Engineering Mechanics, vol.136, issue.1, pp.31-39, 2010. ,
DOI : 10.1061/(ASCE)EM.1943-7889.0000067
A description of micro- and macroscale damage of concrete structures, Engineering Fracture Mechanics, vol.25, issue.5-6, pp.5-6, 1986. ,
DOI : 10.1016/0013-7944(86)90036-6
Free vibration analysis of a cracked beam by finite element method, Journal of Sound and Vibration, vol.273, issue.3, pp.457-475, 2004. ,
DOI : 10.1016/S0022-460X(03)00504-2
Uncertainty calculation in (operational) modal analysis, Mechanical Systems and Signal Processing, vol.21, issue.6, pp.2359-2373, 2007. ,
DOI : 10.1016/j.ymssp.2006.11.007
Uncertainty bounds on modal parameters obtained from stochastic subspace identification, Mechanical Systems and Signal Processing, vol.22, issue.4, pp.948-969, 2008. ,
DOI : 10.1016/j.ymssp.2007.10.009
Challenges in developing confidence intervals on modal parameters estimated for large civil infrastructure with stochastic subspace identification, Structural Control and Health Monitoring, vol.35, issue.3, pp.53-78, 2011. ,
Efficient multi-order uncertainty computation for stochastic subspace identification, Mechanical Systems and Signal Processing, vol.38, issue.2, pp.346-366, 2013. ,
DOI : 10.1016/j.ymssp.2013.01.012
Uncertainty quantification for modal parameters from stochastic subspace identification on multi-setup measurements, Mechanical Systems and Signal Processing, vol.36, issue.2, pp.562-581, 2013. ,
DOI : 10.1016/j.ymssp.2012.11.011
Variance estimation of modal parameters from output-only and input/output subspace-based system identification, Journal of Sound and Vibration, vol.379, pp.1-27, 2016. ,
DOI : 10.1016/j.jsv.2016.05.037
URL : https://hal.archives-ouvertes.fr/hal-01328435
Statistical decision making for damage localization with stochastic load vectors, Mechanical Systems and Signal Processing, vol.39, issue.1-2, pp.426-440, 2013. ,
DOI : 10.1016/j.ymssp.2012.12.011
Robust statistical damage localization with stochastic load vectors, Structural Control and Health Monitoring, vol.36, issue.2, pp.557-573, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01063723
Flexibility-Based Damage Localization from Stochastic Realization Results, Journal of Engineering Mechanics, vol.132, issue.6, pp.651-658, 2006. ,
DOI : 10.1061/(ASCE)0733-9399(2006)132:6(651)
Subspace Identification for Linear Systems: Theory, Implementation, Applications. Kluwer, 1996. ,
DOI : 10.1007/978-1-4613-0465-4
REFERENCE-BASED STOCHASTIC SUBSPACE IDENTIFICATION FOR OUTPUT-ONLY MODAL ANALYSIS, Mechanical Systems and Signal Processing, vol.13, issue.6, pp.855-878, 1999. ,
DOI : 10.1006/mssp.1999.1249
Fast multi-order computation of system matrices in subspace-based system identification, Control Engineering Practice, vol.20, issue.9, pp.882-894, 2012. ,
DOI : 10.1016/j.conengprac.2012.05.005
Effects of environmental and operational variability on structural health monitoring, Philosophical Transactions of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.31, issue.168, pp.539-560, 1851. ,
DOI : 10.1115/1.1410933
Vibration based structural health monitoring of an arch bridge: From automated OMA to damage detection, Mechanical Systems and Signal Processing, vol.28, pp.212-228, 2012. ,
DOI : 10.1016/j.ymssp.2011.06.011
Multiple time series, 1970. ,
