New interface
Journal articles
Simplifying Inclusion–Exclusion Formulas
Abstract : Let = {F1, F2,. . ., Fn} be a family of n sets on a ground set S, such as a family of balls in ℝd. For every finite measure μ on S, such that the sets of are measurable, the classical inclusion–exclusion formula asserts that that is, the measure of the union is expressed using measures of various intersections. The number of terms in this formula is exponential in n, and a significant amount of research, originating in applied areas, has been devoted to constructing simpler formulas for particular families . We provide an upper bound valid for an arbitrary : we show that every system of n sets with m non-empty fields in the Venn diagram admits an inclusion–exclusion formula with m^O(log2n) terms and with ±1 coefficients, and that such a formula can be computed in m^O(log2n) expected time. For every ϵ > 0 we also construct systems with Venn diagram of size m for which every valid inclusion–exclusion formula has the sum of absolute values of the coefficients at least Ω(m^{2−ϵ}).
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-01578188
Contributor : Xavier Goaoc Connect in order to contact the contributor
Submitted on : Monday, August 28, 2017 - 5:15:16 PM
Last modification on : Friday, September 16, 2022 - 1:57:03 PM
Links full text
Identifiers
Citation
Xavier Goaoc, Jiří Matoušek, Pavel Paták, Zuzana Safernová, Martin Tancer. Simplifying Inclusion–Exclusion Formulas. Combinatorics, Probability and Computing, 2015, 24 (02), pp.438 - 456. ⟨10.1017/S096354831400042X⟩. ⟨hal-01578188⟩
Share
Metrics
Record views
86
