Algebraic Geometry for Scientists and Engineers, volume 35 of Mathematical surveys and monographs, Amer. Math. Soc, 1990. ,
Abstract, LMS Journal of Computation and Mathematics, vol.55, pp.139-171, 2013. ,
DOI : 10.4064/aa145-1-5
Differential equations for algebraic functions, Proceedings of the 2007 international symposium on Symbolic and algebraic computation , ISSAC '07, pp.25-32, 2007. ,
DOI : 10.1145/1277548.1277553
URL : https://hal.archives-ouvertes.fr/inria-00138206
Fast solution of toeplitz systems of equations and computation of Pad?? approximants, Journal of Algorithms, vol.1, issue.3, pp.259-295, 1980. ,
DOI : 10.1016/0196-6774(80)90013-9
Plane Algebraic Curves, Birkhaüser, 1986. ,
On fast multiplication of polynomials over arbitrary algebras, Acta Informatica, vol.7, issue.7, pp.693-701, 1990. ,
DOI : 10.1007/BF01178683
Introduction to the Theory of Algebraic Functions of One Variable, Mathematical Surveys. AMS, vol.6, 1951. ,
DOI : 10.1090/surv/006
On the complexity of the D5 principle, ACM SIGSAM Bulletin, vol.39, issue.3, pp.97-98, 2005. ,
DOI : 10.1145/1113439.1113457
About a new method for computing in algebraic number fields, EUROCAL 85, 1985. ,
Diverses questions relatives au calcul formel avec des nombres algébriques, 1987. ,
Rational Puiseux expansions, Compositio Math, vol.70, issue.2, pp.119-154, 1989. ,
Death of Marc Rybowicz, aged 52, ACM Communications in Computer Algebra, vol.50, issue.4, pp.191-191, 2017. ,
DOI : 10.1145/3055282.3055300
Introduction to the Theory of Algebraic Numbers and Functions, 1966. ,
Modern Computer Algebra, 2013. ,
Solving multivariate algebraic equations by Hensel construction, Japan J. of Industrial and Applied Math, vol.16, pp.257-285, 1999. ,
All Algebraic Functions Can Be Computed Fast, Journal of the ACM, vol.25, issue.2, pp.245-260, 1978. ,
DOI : 10.1145/322063.322068
URL : http://repository.cmu.edu/cgi/viewcontent.cgi?article=3139&context=compsci
A Fast Algorithm for Computing the Truncated Resultant, Proceedings of the ACM on International Symposium on Symbolic and Algebraic Computation, ISSAC '16, pp.1-8, 2016. ,
DOI : 10.1007/BF00289520
URL : https://hal.archives-ouvertes.fr/hal-01366386
Multivariate Polynomial Factorization, Journal of the ACM, vol.22, issue.2, pp.291-308, 1975. ,
DOI : 10.1145/321879.321890
Linear Differential Operators for Polynomial Equations, Journal of Symbolic Computation, vol.34, issue.5, pp.355-398, 2002. ,
DOI : 10.1006/jsco.2002.0564
URL : https://doi.org/10.1006/jsco.2002.0564
Change of order for bivariate triangular sets, Proceedings of the 2006 international symposium on Symbolic and algebraic computation , ISSAC '06, pp.277-284, 2006. ,
DOI : 10.1145/1145768.1145814
Calcul de développements de Puiseux et application au calcul de groupe de monodromie d'une courbe algébrique plane, 2008. ,
Good reduction of puiseux series and complexity of the Newton-Puiseux algorithm over finite fields, Proceedings of the twenty-first international symposium on Symbolic and algebraic computation, ISSAC '08, pp.239-246, 2008. ,
DOI : 10.1145/1390768.1390802
URL : https://hal.archives-ouvertes.fr/hal-00320600
Complexity bounds for the rational Newton-Puiseux algorithm over finite fields, Applicable Algebra in Engineering, Communication and Computing, vol.69, issue.1???2, pp.187-217, 1007. ,
DOI : 10.1090/S0025-5718-00-01246-1
URL : https://hal.archives-ouvertes.fr/hal-00601438
Good reduction of Puiseux series and applications, Journal of Symbolic Computation, vol.47, issue.1, pp.32-63, 2012. ,
DOI : 10.1016/j.jsc.2011.08.008
URL : https://hal.archives-ouvertes.fr/hal-00825850
Improving Complexity Bounds for the Computation of Puiseux Series over Finite Fields, Proceedings of the 2015 ACM on International Symposium on Symbolic and Algebraic Computation, ISSAC '15, pp.299-306, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01253216
On the complexity of computing with zero-dimensional triangular sets, Journal of Symbolic Computation, vol.50, issue.0, pp.110-138, 2013. ,
DOI : 10.1016/j.jsc.2012.05.008
URL : https://hal.archives-ouvertes.fr/hal-00825847
Fast multiplication of large numbers, Computing, vol.150, issue.3-4, pp.281-292, 1971. ,
DOI : 10.1007/BF02242355
Fast Construction of Irreducible Polynomials over Finite Fields, Journal of Symbolic Computation, vol.17, issue.5, pp.371-391, 1994. ,
DOI : 10.1006/jsco.1994.1025
Algebraic Curves, 1950. ,
Bivariate Factorization Using a Critical Fiber, Foundations of Computational Mathematics, vol.58, issue.6, pp.1-45, 2016. ,
DOI : 10.1016/j.jsc.2013.05.011
URL : https://hal.archives-ouvertes.fr/hal-01645143
