A 45.5µW 15fps Always-On CMOS image sensor for Mobile and Wearable Devices IEEE Int. Solid-State Circuits Conf, ISSCC) Dig. Tech. Papers, pp.114-117, 2015. ,
A 187.5Vrms-Read-Noise 51mW 1.4Mpixel CMOS Image Sensor with PMOSCAP Column CDS and 10b Self-Differential Offset-Cancelled Pipeline SAR-ADC IEEE ISSCC 2012, pp.494-496 ,
A High-Speed Low-Noise CMOS Image Sensor With 13-b Column-Parallel Single-Ended Cyclic ADCs, IEEE Transactions on Electron Devices, vol.56, issue.11, pp.2414-2422, 2009. ,
DOI : 10.1109/TED.2009.2030635
A 33 mpixel 120 fps cmos image sensor using 12 b column-parallel pipelined cyclic adcs, IEEE ISSCC Dig. Tech. Papers, vol.2012, pp.388-389 ,
DOI : 10.1109/isscc.2012.6177047
CMOS Image Sensor With Per-Column ΣΔ ADC and Programmable Compressed Sensing, IEEE Journal of Solid-State Circuits, vol.48, issue.1, 2013. ,
DOI : 10.1109/JSSC.2012.2214851
Compressed sensing, IEEE Transactions on Information Theory, vol.52, issue.4, pp.1289-1306, 2006. ,
DOI : 10.1109/TIT.2006.871582
URL : https://hal.archives-ouvertes.fr/inria-00369486
Implementation of Steerable Spatiotemporal Image Filters on the Focal Plane IEEE TCAS-II, 2002. ,
Compressive sensing on a CMOS separable-transform image sensor Proc, IEEE, 2010. ,
DOI : 10.1109/jproc.2010.2041422
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.212.2313
The compressive multiplexer for multi-channel compressive sensing, 2011 IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), pp.3980-3983, 2011. ,
DOI : 10.1109/ICASSP.2011.5947224
Design and Analysis of a Hardware-Efficient Compressed Sensing Architecture for Data Compression in Wireless Sensors, IEEE Journal of Solid-State Circuits, vol.47, issue.3, 2012. ,
DOI : 10.1109/JSSC.2011.2179451
Factorization for Analog-to-Digital Matrix Multiplication Report, 2013. ,
DOI : 10.1109/icassp.2015.7178132
A 2.1Mpixel 120 frame/s CMOS image sensor with column-parallel ADC architecture IEEE JSSC, pp.236-247, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00022217
A 2.5GHz 7.7TOPS/W Switched-Capacitor Matrix Multiplier with Codesigned Local Memory in 40nm, IEEE ISSCC, vol.2016, pp.418-420 ,
URL : https://hal.archives-ouvertes.fr/hal-01302815
A 17.7 Mpixel 120 fps CMOS image sensor with 34.8 Gb/s readout IEEE Int. Solid-State Circuits Conf, pp.2011420-422 ,
ADC Performance Survey, 1997. ,
A matrix-multiplying ADC implementing a machine-learning classifier directly with data conversion ISSCC 2015, pp.1-3 ,
DOI : 10.1109/isscc.2015.7063061
A 64 fJ/step 9-bit SAR ADC Array With Forward Error Correction and Mixed-Signal CDS for CMOS Image Sensors, IEEE Transactions on Circuits and Systems I: Regular Papers, vol.61, issue.11, 2014. ,
DOI : 10.1109/TCSI.2014.2334852
CMOS Data converters for communication A 50-fJ 10-b 160-MS/s Pipelined-SAR ADC Decoupled Flip-Around MDAC and Self-Embedded Off, 2000. ,
Modeling of capacitor array mismatch effect in embedded, CMOS CR SAR ADC Proc. 6th Int. Conf. ASICs 2005, pp.979-982 ,
