The multivariate skew-normal distribution, Biometrika, vol.83, pp.715-726, 1996. ,
DOI : 10.1017/cbo9781139248891.006
On nomenclature for, and the relative merits of, two formulations of skew distributions, Statistics and Probability Letters, vol.110, pp.201-206, 2016. ,
Assessing a mixture model for clustering with the integrated completed likelihood, pp.719-725, 2000. ,
Bayesian Cluster Analysis, Biometrika, vol.65, pp.31-38, 1978. ,
Approximations to Bayesian Clustering Rules, Biometrika, vol.68, pp.275-285, 1981. ,
DOI : 10.2307/2335828
High-content flow cytometry and temporal data analysis for defining a cellular signature of graft-versus-host disease. Biology of blood and marrow transplantation : journal of the American Society for, Blood and Marrow Transplantation, vol.13, pp.691-700, 2007. ,
Bayesian nonparametric PlackettLuce models for the analysis of preferences for college degree programmes, The Annals of Applied Statistics, vol.8, pp.1145-1181, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00755478
Bayesian Inference for Linear Dynamic Models With Dirichlet Process Mixtures, IEEE Transactions on Signal Processing, vol.56, pp.71-84, 2008. ,
DOI : 10.1109/tsp.2007.900167
URL : https://hal.archives-ouvertes.fr/inria-00129646
Generalized Pólya Urn for Time-Varying Pitman-Yor Processes, Journal of Machine Learning Research, vol.18, pp.1-32, 2017. ,
Statistical mixture modeling for cell subtype identification in flow cytometry, Cytometry. Part A : the journal of the International Society for Analytical Cytology, vol.73, pp.693-701, 2008. ,
Hierarchical modeling for rare event detection and cell subset alignment across flow cytometry samples, PLoS computational biology, vol.9, p.1003130, 2013. ,
DOI : 10.1371/journal.pcbi.1003130
URL : https://journals.plos.org/ploscompbiol/article/file?id=10.1371/journal.pcbi.1003130&type=printable
Model-Based Clustering for Expression Data via a Dirichlet Process Mixture Model, vol.10, pp.201-218, 2006. ,
DOI : 10.1017/cbo9780511584589.011
A non-parametric Bayesian model for joint cell clustering and cluster matching: identification of anomalous sample phenotypes with random effects, BMC Bioinformatics, vol.15, p.314, 2014. ,
Bayesian Density Estimation and Inference Using Mixtures, Journal of the American Statistical Association, vol.90, pp.577-588, 1995. ,
DOI : 10.1080/01621459.1995.10476550
A Bayesian analysis of some nonparametric problems. The Annals of Statistics, vol.1, pp.209-230, 1973. ,
Merging mixture components for cell population identification in flow cytometry, Advances in bioinformatics, 2009. ,
DOI : 10.1155/2009/247646
URL : http://downloads.hindawi.com/journals/abi/2009/247646.pdf
Optimizing transformations for automated, high throughput analysis of flow cytometry data, BMC Bioinformatics, vol.11, p.546, 2010. ,
Improved criteria for clustering based on the B.P. HEJBLUM ET AL. posterior similarity matrix, Bayesian Analysis, vol.4, pp.367-392, 2009. ,
Bayesian inference for finite mixtures of univariate and multivariate skew-normal and skew-t distributions, Biostatistics, vol.11, pp.317-353, 2010. ,
flowPeaks: a fast unsupervised clustering for flow cytometry data via K-means and density peak finding, Bioinformatics, vol.28, pp.2052-2058, 2012. ,
DOI : 10.1093/bioinformatics/bts300
URL : https://academic.oup.com/bioinformatics/article-pdf/28/15/2052/646633/bts300.pdf
Multi-parametric cytometry from a complex cellular sample: Improvements and limits of manual versus computational-based interactive analyses. Cytometry Part A, vol.89, pp.480-490, 2016. ,
Supplement to "Sequential Dirichlet process mixtures of multivariate skew tdistributions for model-based clustering of flow cytometry data, 2018. ,
Sampling for Bayesian Computation with Large Datasets, SSRN Electronic Journal, pp.1-21, 2005. ,
DOI : 10.2139/ssrn.1010107
URL : http://www.stat.columbia.edu/~gelman/research/unpublished/comp7.pdf
Simple Marginally Noninformative Prior Distributions for Covariance Matrices, Bayesian Analysis, vol.8, pp.439-452, 2013. ,
DOI : 10.1214/13-ba815
URL : https://doi.org/10.1214/13-ba815
Markov Chain Monte Carlo Methods and the Label Switching Problem in Bayesian Mixture Modeling, Statistical Science, vol.20, pp.50-67, 2005. ,
BayesFlow: latent modeling of flow cytometry cell populations, BMC Bioinformatics, vol.17, p.25, 2016. ,
Model-Based Clustering of Non-Gaussian Panel Data Based on Skew-t Distributions, Journal of Business & Economic Statistics, vol.28, pp.52-66, 2010. ,
Slice sampling mixture models, Statistics and Computing, vol.21, pp.93-105, 2011. ,
Marginally specified priors for non-parametric bayesian estimation, Journal of the Royal Statistical Society. Series B: Statistical Methodology, vol.77, pp.35-58, 2015. ,
From "truly na¨?vena¨?ve" to "exhausted senescent" T cells: When markers predict functionality, Cytometry Part A, vol.85, pp.25-35, 2014. ,
Bayesian Model-Based Clustering Procedures, Journal of Computational and Graphical Statistics, vol.16, pp.526-558, 2007. ,
On mixtures of skew normal and skew tdistributions, Advances in Data Analysis and Classification, vol.7, pp.241-266, 2013. ,
Finite mixtures of canonical fundamental skew t-distributions: The unification of the restricted and unrestricted skew t-mixture models, Statistics and Computing, vol.26, pp.573-589, 2016. ,
Effect of intermittent interleukin-2 therapy on CD4+ T-cell counts following antiretroviral cessation in patients with HIV, AIDS, vol.26, pp.711-720, 2012. ,
Dendritic cell-based therapeutic vaccine elicits polyfunctional HIV-specific T-cell immunity associated with control of viral load, European journal of immunology, vol.44, pp.2802-2810, 2014. ,
, , 2013.
, Hierarchical Bayesian mixture modelling for antigen-specific T-cell subtyping in combinatorially encoded flow cytometry studies, Statistical Applications in Genetics and Molecular Biology, vol.12, pp.309-331
On a class of Bayesian nonparametric estimates: I. Density estimates, The Annals of Statistics, vol.12, pp.351-357, 1984. ,
Automated gating of flow cytometry data via robust model-based clustering, Cytometry. Part A : the journal of the International Society for Analytical Cytology, vol.73, pp.321-332, 2008. ,
Flexible mixture modeling via the multivariate t distribution with the Box-Cox transformation: An alternative to the skew-t distribution, Statistics and Computing, vol.22, pp.33-52, 2012. ,
Comment on On nomenclature, and the relative merits of two formulations of skew distributions by A, Statistics & Probability Letters, vol.116, pp.1-5, 2016. ,
Bayesian infinite mixture model based clustering of gene expression profiles, Bioinformatics, vol.18, pp.1194-1206, 2002. ,
Cluster stability in the analysis of mass cytometry data, Cytometry Part A, vol.91, pp.73-84, 2017. ,
SWIFT-scalable clustering for automated identification of rare cell populations in large, high-dimensional flow cytometry datasets, Part 2: Biological evaluation, Cytometry Part A, vol.85, pp.422-433, 2014. ,
Mixtures of skew-t factor analyzer, Computational Statistics & Data Analysis, vol.77, pp.326-335, 2014. ,
SWIFT-scalable clustering for automated identification of rare cell populations in large, high-dimensional flow cytometry datasets, Part 1: Algorithm design, Cytometry Part A, vol.85, pp.408-421, 2014. ,
Slice sampling, The Annals of Statistics, vol.31, pp.705-767, 2003. ,
, Combinatorial Stochastic Processes. Lecture Notes in Mathematics 1875, 2006.
Automated high-dimensional flow cytometric data analysis, Proceedings of the National Academy of Sciences of the United States of America, vol.106, pp.8519-8524, 2009. ,
Elucidation of seventeen human peripheral blood B-cell subsets and quantification of the tetanus response using a density-based method for the automated identification of cell populations in multidimensional flow cytometry data, Cytometry. Part B, Clinical cytometry, vol.78, pp.69-82, 2010. ,
A constructive definition of Dirichlet priors, Statistica Sinica, vol.4, pp.639-650, 1994. ,
Misty Mountain clustering: application to fast unsupervised flow cytometry gating, BMC Bioinformatics, vol.11, p.502, 2010. ,
Dirichlet Process, Encyclopedia of Machine Learning 280-287, 2010. ,
Immunological markers after long-term treatment interruption in chronically HIV-1 infected patients with CD4 cell count above 400 x 10(6) cells/l, AIDS, vol.19, pp.53-61, 2005. ,
Estimating the number of clusters in a data set via the gap statistic, Journal of the Royal Statistical Society: Series B (Statistical Methodology), vol.63, pp.411-423, 2001. ,
Metropolis-Hastings within Partially Collapsed Gibbs Samplers, Journal of Computational and Graphical Statistics, vol.24, pp.301-327, 2015. ,
Partially Collapsed Gibbs Samplers, Journal of the American Statistical Association, vol.103, pp.790-796, 2008. ,
Harmonization of the intracellular cytokine staining assay, Cancer Immunology, Immunotherapy, vol.61, pp.967-978, 2012. ,
Data reduction for spectral clustering to analyze high throughput flow cytometry data, BMC Bioinformatics, vol.11, p.403, 2010. ,
, boris.hejblum@u-bordeaux.fr chariff.alkhassim@u-bordeaux.fr rodolphe.thiebaut@u-bordeaux.fr R. Gottardo Fred Hutchinson Cancer Research Center 1100 Fairview Ave. N., Mail Stop, pp.1-514
