Dynamically Distributed Network Control for Message Dissemination in ITS
We propose D2-ITS, a flexible and extensible framework to dynamically distribute network control to enable message dissemination in Intelligent Transport Systems (ITS). By decoupling the control- from the data plane, D2-ITS leverages network programmability to address ITS scalability, delay intolerance and decentralization. It uses a distributed control plane based on a hierarchy of controllers that can dynamically adjust to environment and network conditions in order to satisfy ITS application requirements. We demonstrate the benefits of D2-ITS through a proof-of-concept prototype using the ns-3 simulation platform. Results indicate lower message delivery latency with minimal additional overhead.
