Enhancement of Thermoelectric Efficiency in PbTe by Distortion of the Electronic Density of States, Science, vol.111, issue.22, pp.554-557, 2008. ,
DOI : 10.1103/PhysRev.111.1029
Thin-film thermoelectric devices with high room-temperature figures of merit, Nature, vol.78, issue.6856, pp.597-602, 2001. ,
DOI : 10.1063/1.1356455
The high performance of a thin film thermoelectric generator with heat flow running parallel to film surface, Applied Physics Letters, vol.102, issue.3, p.33904, 2013. ,
DOI : 10.1016/S0167-577X(99)00239-6
CRC handbook of thermoelectrics, 1995. ,
DOI : 10.1201/9781420049718
Effects of in-doping on the thermoelectric properties of ??-Zn4Sb3, Intermetallics, vol.12, issue.7-9, pp.809-813, 2004. ,
DOI : 10.1016/j.intermet.2004.02.030
Effects of Nb doping on thermoelectric properties of Zn4Sb3 at high temperatures, Journal of Materials Research, vol.24, issue.02, pp.430-435, 2009. ,
DOI : 10.1016/j.jallcom.2003.10.001
Optical and electronic properties of metal doped thermoelectric Zn4Sb3, Journal of Applied Physics, vol.51, issue.12, pp.123524-123525, 2008. ,
DOI : 10.1103/PhysRevB.74.134108
Rational Synthesis of Metastable Skutterudite Compounds Using Multilayer Precursors, Journal of the American Chemical Society, vol.119, issue.11, pp.2665-2668, 1997. ,
DOI : 10.1021/ja964084g
Thin film deposition: a novel synthetic route to new materials, Journal of Materials Chemistry, vol.9, issue.1, pp.233-242, 1999. ,
DOI : 10.1039/a804929g
High-performance In filled CoSb3 nano thin films fabricated by multi-step co-sputtering method, Journal of Alloys and Compounds, vol.639, pp.74-78, 2015. ,
DOI : 10.1016/j.jallcom.2015.03.149
Structural characterization of thermally evaporated Bi2Te3 thin films, Journal of Physics and Chemistry of Solids, vol.68, issue.1, pp.111-117, 2007. ,
DOI : 10.1016/j.jpcs.2006.09.014
The influence of the transformation of electronic structure and micro-structure on improving the thermoelectric properties of zinc antimonide thin films, Intermetallics, vol.64, pp.18-22, 2015. ,
DOI : 10.1016/j.intermet.2015.04.012
Thermoelectric properties of Zn4Sb3 thin films prepared by magnetron sputtering, Thin Solid Films, vol.443, issue.1-2, pp.84-90, 2013. ,
DOI : 10.1016/S0040-6090(03)00855-1
