Reports
On wave breaking for Boussinesq-type models
Maria Kazolea 1 Mario Ricchiuto 1
1 CARDAMOM - Certified Adaptive discRete moDels for robust simulAtions of CoMplex flOws with Moving fronts
IMB - Institut de Mathématiques de Bordeaux, Inria Bordeaux - Sud-Ouest
Abstract : We considers the issue of wave breaking closure for Boussinesq type models, and attempt at providing some more understanding of the sensitivity of some closure approaches to the numerical set-up. In particular, we are interested in the potential for mesh refinement, and in quantifying the dissipation mechanism active. Two closure strategies are considered. The first is an eddy viscosity approach following some early work by O. Nwogu in the 90's, and some more recent developments by Zhang and co-workers. In this model, a breaking viscosity is computed starting form a turbulent kinetic energy. The latter is obtained from an ad-hoc partial differential equation, which is solved in parallel with the propagation model. The second approach considered consists in suppressing the dispersive terms in breaking regions. The dissipation of total energy obtained in a shallow water shock is used to model the energy dissipation due to breaking. Due to its simplicity and effectiveness, the second approach has gained substantial attention in the coastal engineering community. Here we propose a systematic comparison of the two approaches, to understand more of their sensitivity w.r.t. the type of propagation model used (weakly or fully non-linear), to the type of breaking wave being simulated, as well as to understand the mesh dependence of the pointwise results obtained, and in particular the potential for achieving mesh converged simulations. Finally, we provide a quantitative analysis of the dissipation introduced by the two closures for a moving breaking bore.
Complete list of metadata
Cited literature [94 references]  Display  Hide  Download
https://hal.inria.fr/hal-01581954
Contributor : Maria Kazolea Connect in order to contact the contributor
Submitted on : Tuesday, September 5, 2017 - 1:23:33 PM
Last modification on : Wednesday, February 2, 2022 - 3:54:24 PM
File
KR17.pdf
Identifiers
  • HAL Id : hal-01581954, version 1
Collections
Citation
Maria Kazolea, Mario Ricchiuto. On wave breaking for Boussinesq-type models. [Research Report] RR-9092, INRIA. 2017, pp.37. ⟨hal-01581954⟩
Share
Metrics
Record views
210
Files downloads
440
