An Approximate Minimum Degree Ordering Algorithm, SIAM Journal on Matrix Analysis and Applications, vol.17, issue.4, pp.886-905, 1996. ,
DOI : 10.1137/S0895479894278952
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.25.8417
Multifrontal parallel distributed symmetric and unsymmetric solvers, Computer Methods in Applied Mechanics and Engineering, vol.184, issue.2-4, pp.501-520, 2000. ,
DOI : 10.1016/S0045-7825(99)00242-X
URL : https://hal.archives-ouvertes.fr/hal-00856651
A Supernodal Approach to Sparse Partial Pivoting, SIAM Journal on Matrix Analysis and Applications, vol.20, issue.3, pp.720-755, 1999. ,
DOI : 10.1137/S0895479895291765
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.131.6235
Nested Dissection of a Regular Finite Element Mesh, SIAM Journal on Numerical Analysis, vol.10, issue.2, pp.345-363, 1973. ,
DOI : 10.1137/0710032
Numerical solutions in primal and dual mesh of magnetostatic problem solved with the finite integration technique, pp.47-55, 2008. ,
Technique de prise en compte de grandeurs globales appliquées à la technique d'intégration finis dans le cas de la des problèmes électrocinétique, RIGE, vol.11, pp.2-3, 2008. ,
DOI : 10.3166/rige.11.185-203
Iterative Methods for Sparse Linear Systems, 2003. ,
DOI : 10.1137/1.9780898718003
A discretization method for the solution of Maxwell's equations for six-component fields, Electron. Commun. (AEÜ), vol.31, issue.3, pp.116-120, 1977. ,
The Algebraic Eigenvalue Problem, 1965. ,
