Enabling Cross-Technology Mobile Applications with Network-Aware References - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Kevin Pinte
  • Fonction : Auteur
  • PersonId : 1003814
Dries Harnie
  • Fonction : Auteur
  • PersonId : 1003813
Theo D’hondt
  • Fonction : Auteur
  • PersonId : 1015678
Mobile devices, such as smart phones, have become ubiquitous. This evolution has given rise to a vast ecosystem of mobile applications. Typically these applications only use a small subset of the networking technologies at their disposal. Building applications that use multiple networking technologies simultaneously or exploit knowledge about the available connections is a laborious task. Programmers must manually keep track of the connectivity state and duplicate communication code per connection type. This paper presents network-aware references, a distributed object-oriented programming abstraction that eases multi-networking for mobile applications and allows programmers to react to changes in the connectivity of different networks around them. We show how network-aware references are implemented and evaluate how well they switch between technologies.
978-3-642-21464-6_10_Chapter.pdf (258.04 Ko) Télécharger le fichier
hal-01582992 , version 1 (06-09-2017)
Paternité
Kevin Pinte, Dries Harnie, Theo D’hondt. Enabling Cross-Technology Mobile Applications with Network-Aware References. 13th Conference on Coordination Models and Languages (COORDINATION), Jun 2011, Reykjavik, Iceland. pp.142-156, ⟨10.1007/978-3-642-21464-6_10⟩. ⟨hal-01582992⟩
44 Consultations
74 Téléchargements
