Session Typing for a Featherweight Erlang - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
As software tends to be increasingly concurrent, the paradigm ofmessage passing is becoming more prominent in computing. The language Erlang offers an intuitive and industry-testedimplementation of process-oriented programming, combining pattern-matching with message mailboxes, resulting in concise, elegant programs. However, it lacks a successful static verification mechanism that ensures safety and determinism of communications with respect to well-defined specifications. We present a session typing system for a featherweight Erlang calculus that encompasses the main communication abilities of the language. In this system, structured types are used to govern the interaction of Erlang processes, ensuring that their behaviour is safe with respect to a defined protocol. The expected properties of subject reduction and type safety are established.
978-3-642-21464-6_7_Chapter.pdf (370.09 Ko) Télécharger le fichier
hal-01582995 , version 1 (06-09-2017)
Paternité
Dimitris Mostrous, Vasco T. Vasconcelos. Session Typing for a Featherweight Erlang. 13th Conference on Coordination Models and Languages (COORDINATION), Jun 2011, Reykjavik, Iceland. pp.95-109, ⟨10.1007/978-3-642-21464-6_7⟩. ⟨hal-01582995⟩
105 Consultations
152 Téléchargements
