New interface
Conference papers
Monitoring Distributed Systems Using Knowledge
Abstract : In this paper, we use knowledge-based control theory to monitor global properties in a distributed system. We control the system to enforce that if a given global property is violated, at least one process knows this fact, and therefore may report it. Our approach uses knowledge properties that are precalculated based on model checking. As local knowledge is not always sufficient to monitor a global property in a concurrent system, we allow adding temporary synchronizations between two or more processes to achieve sufficient knowledge. Since synchronizations are expensive, we aim at minimizing their number using the knowledge analysis.
Complete list of metadata
Cited literature [16 references]  Display  Hide  Download
https://hal.inria.fr/hal-01583313
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Thursday, September 7, 2017 - 11:10:10 AM
Last modification on : Friday, November 19, 2021 - 12:42:03 PM
File
978-3-642-21461-5_12_Chapter.p...
Identifiers
Citation
Susanne Graf, Doron Peled, Sophie Quinton. Monitoring Distributed Systems Using Knowledge. 13th Conference on Formal Methods for Open Object-Based Distributed Systems (FMOODS) / 31th International Conference on FORmal TEchniques for Networked and Distributed Systems (FORTE), Jun 2011, Reykjavik,, Iceland. pp.183-197, ⟨10.1007/978-3-642-21461-5_12⟩. ⟨hal-01583313⟩
Share
Metrics
Record views
233
Files downloads
80
