Abstract : We present a novel way of encapsulating UML activities using interface contracts, which allows to verify functional properties that depend on the synchronization of parallel instances of software components. Encapsulated UML activities can be reused together with their verification results in SPACE, a model-driven engineering method for reactive systems. Such compositional verification significantly improves the scalability of the method. Employing a small example of a load balancing system, we explain the semantics of the contracts using the temporal logic TLA. Thereafter, we propose a more easily comprehensible graphical notation and clarify that the contracts are able to express the variants of multiplicity that we can encounter using UML activities. Finally, we give the results of verifying some properties of the example system using the TLC model checker.
https://hal.inria.fr/hal-01583314
Contributor : Hal Ifip <>
Submitted on : Thursday, September 7, 2017 - 11:10:12 AM Last modification on : Monday, September 11, 2017 - 10:47:03 AM
Vidar Slåtten, Peter Herrmann. Contracts for Multi-instance UML Activities. 13th Conference on Formal Methods for Open Object-Based Distributed Systems (FMOODS) / 31th International Conference on FORmal TEchniques for Networked and Distributed Systems (FORTE), Jun 2011, Reykjavik,, Iceland. pp.304-318, ⟨10.1007/978-3-642-21461-5_20⟩. ⟨hal-01583314⟩
