Linear-Time and May-Testing in a Probabilistic Reactive Setting - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We consider reactive probabilistic labelled transition systems (rplts), a model where internal choices are refined by probabilistic choices. In this setting, we study the relationship between linear-time and may-testing semantics, where an angelic view of nondeterminism is taken. Building on the model of d-trees of Cleaveland et al., we first introduce a clean model of probabilistic may-testing, based on simple concepts from measure theory. In particular, we define a probability space where statements of the form “p may pass test o” naturally correspond to measurable events. We then obtain an observer-independent characterization of the may-testing preorder, based on comparing the probability of sets of traces, rather than of individual traces. This entails that may-testing is strictly finer than linear-time semantics. Next, we characterize the may-testing preorder in terms of the probability of satisfying safety properties, expressed as languages of infinite trees rather than traces. We then identify a significative subclass of rplts where linear and may-testing semantics do coincide: these are the separated rplts, where actions are partitioned into probabilistic and nondeterministic ones, and at each state only one type is available.
978-3-642-21461-5_2_Chapter.pdf (165.01 Ko) Télécharger le fichier
hal-01583326 , version 1 (07-09-2017)
Paternité
Lucia Acciai, Michele Boreale, Rocco De Nicola. Linear-Time and May-Testing in a Probabilistic Reactive Setting. 13th Conference on Formal Methods for Open Object-Based Distributed Systems (FMOODS) / 31th International Conference on FORmal TEchniques for Networked and Distributed Systems (FORTE), Jun 2011, Reykjavik,, Iceland. pp.29-43, ⟨10.1007/978-3-642-21461-5_2⟩. ⟨hal-01583326⟩
40 Consultations
86 Téléchargements
