Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, EpiSciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Abstract : A major challenge in network virtualization is to virtualize the components constituting the network, in particular the routers. In the work presented here, we focus on how to use open source Linux software in combination with commodity hardware to build open virtual routers. A general approach in open router virtualization is to run multiple virtual instances in parallel on the same PC hardware. This means that virtual components are combined in the router’s data plane, which can result in performance penalty. In this paper, we investigate the impact of the design of virtual network devices on router performance in Linux namespace environment. We identify performance bottlenecks along the packet data path. We suggest design changes to improve performance. In particular, we investigate modifications of the “macvlan” device, and analyze the performance improvements in terms of packet forwarding. We also investigate how the number of virtual routers and virtual devices within a physical machine influence performance.
https://hal.inria.fr/hal-01583400 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Thursday, September 7, 2017 - 11:57:39 AM Last modification on : Thursday, September 7, 2017 - 3:24:25 PM
Muhammad Siraj Rathore, Markus Hidell, Peter Sjödin. Data Plane Optimization in Open Virtual Routers. 10th IFIP Networking Conference (NETWORKING), May 2011, Valencia, Spain. pp.379-392, ⟨10.1007/978-3-642-20757-0_30⟩. ⟨hal-01583400⟩
