IPv4 Address Report, 2010. ,
A Tree Based Router Search Engine Architecture with Single Port Memories, ACM Sigarch Com. Arch, vol.33, issue.2, 2005. ,
DOI : 10.1109/isca.2005.7
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.101.1903
FlashTrie: Hash-based Prefix-Compressed Trie for IP Route Lookup Beyond 100Gbps, 2010 Proceedings IEEE INFOCOM, 2010. ,
DOI : 10.1109/INFCOM.2010.5462142
High Performance Switches and Routers, 2007. ,
DOI : 10.1002/0470113952
Introduction to Algorithms, 2003. ,
Small forwarding tables for fast routing lookups, 1997. ,
DOI : 10.1145/263109.263133
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.104.7434
Tree bitmap, ACM SIGCOMM Computer Communication Review, vol.34, issue.2, 2004. ,
DOI : 10.1145/997150.997160
Routing lookups in hardware at memory access speeds, Proceedings. IEEE INFOCOM '98, the Conference on Computer Communications. Seventeenth Annual Joint Conference of the IEEE Computer and Communications Societies. Gateway to the 21st Century (Cat. No.98CH36169), 1998. ,
DOI : 10.1109/INFCOM.1998.662938
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.21.9617
CHAP: Enabling Efficient Hardware-Based Multiple Hash Schemes for IP Lookup, IFIP Networking, vol.46, issue.12, 2009. ,
DOI : 10.1109/12.641938
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.153.2193
Progressive hashing for packet processing using set associative memory, Proceedings of the 5th ACM/IEEE Symposium on Architectures for Networking and Communications Systems, ANCS '09, 2009. ,
DOI : 10.1145/1882486.1882521
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.156.4068
Advanced hashing schemes for packet forwarding using set associative memory architectures, Journal of Parallel and Distributed Computing, vol.71, issue.1, pp.1-15, 2011. ,
DOI : 10.1016/j.jpdc.2010.10.006
URL : http://d-scholarship.pitt.edu/9726/1/Michel_Hanna_Nov_2009.pdf
Multi-terabit ip lookup using parallel bidirectional pipelines, Proceedings of the 2008 conference on Computing frontiers , CF '08, 2008. ,
DOI : 10.1145/1366230.1366273
URL : http://cial.csie.ncku.edu.tw/presentation/group_pdf/Multi-terabit_ip_lookup_using_parallel_bidirectional_pipelines.pdf
Efficient Construction of Pipelined Multibit-Trie Router-Tables, IEEE Transactions on Computers, vol.56, issue.1, 2007. ,
DOI : 10.1109/TC.2007.250621
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.81.9120
Comparative Studies of Address Lookup Algorithms for IPv6, IEEE ICACT, 2006. ,
Tree, Segment Table, and Route Bucket: A Multi-Stage Algorithm for IPv6 Routing Table Lookup, IEEE INFOCOM 2007, 26th IEEE International Conference on Computer Communications, 2007. ,
DOI : 10.1109/INFCOM.2007.294
IP-address lookup using LC-tries, IEEE Journal on Selected Areas in Communications, vol.17, issue.6, 1999. ,
DOI : 10.1109/49.772439
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.132.4190
Survey and taxonomy of IP address lookup algorithms, IEEE Network, vol.15, issue.2, 2001. ,
DOI : 10.1109/65.912716
Fast updating algorithms for TCAM, IEEE Micro, vol.21, issue.1, 2001. ,
DOI : 10.1109/40.903060
Fast address lookups using controlled prefix expansion, ACM Transactions on Computer Systems, vol.17, issue.1, 1999. ,
DOI : 10.1145/296502.296503
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.14.3830
CACTI 5.1: An Integrated Cache Timing, Power, and Area Model ,
Network Algorithmics, 2005. ,
DOI : 10.1201/9781584888215-c28
TCAM-Based Forwarding Engine with Minimum Independent Prefix Set (MIPS) for Fast Updating, 2006 IEEE International Conference on Communications, 2006. ,
DOI : 10.1109/ICC.2006.254712
