Online Dynamic Monitoring of MPI Communications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
As the complexity and diversity of computer hardware and the elaborateness of network technologies have made the implementation of portable and efficient algorithms more challenging, the need to understand application communication patterns has become increasingly relevant. This paper presents details of the design and evaluation of a communication-monitoring infrastructure developed in the Open MPI software stack that can expose a dynamically configurable level of detail concerning application communication patterns.
mpimonitoring.pdf (468.97 Ko) Télécharger le fichier
hal-01583498 , version 1 (07-09-2017)
  • HAL Id : hal-01583498 , version 1
George Bosilca, Clément Foyer, Emmanuel Jeannot, Guillaume Mercier, Guillaume Papauré. Online Dynamic Monitoring of MPI Communications. Euro-Par 2017 Parallel Processing, Aug 2017, Santiago de Compostella, Spain. ⟨hal-01583498⟩
196 Consultations
422 Téléchargements
